Введение
This is a prerequisite guide that will instruct you on how to properly open your keyboard. This will be helpful for replacing internal components without damaging your device.
Выберете то, что вам нужно
Peel off the center sticker to reveal two hidden 4.0 mm screws.
Unscrew these two screws with a Phillips #1 screwdriver.
Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
Wedge the flat end of the spudger between the back panel and front panel.
Slide the flat end of the spudger from right to left to pry the two panels apart.
2 человек успешно провели ремонт по этому руководству.
