Logitech Harmony Ultimate Buttons Replacement
Выберете то, что вам нужно
    1. Logitech Harmony Ultimate Buttons Replacement, Battery: шаг 1, изображение 1 из 1
      • Remove the single 6 mm Phillips #0 screw located beneath the sticker near the USB charging port.
      Спросите у FixBot
      Добавить комментарий
    2. Logitech Harmony Ultimate Buttons Replacement: шаг 2, изображение 1 из 2 Logitech Harmony Ultimate Buttons Replacement: шаг 2, изображение 2 из 2
      • Use a plastic opening tool to release tabs that hold the front panel and back panel together. There are three tabs on each side of the device that need to separate for the device to open.
      • The use of a plastic opening tool is recommended to avoid damaging the remote. Use stronger tools as a last resort.
      • Be careful on the right side (looking at the back side) not to hit the screen ribbon cable. If that is hit and breaks, the touchscreen will not work properly. (example shown in the image)
      Спросите у FixBot
    3. Logitech Harmony Ultimate Buttons Replacement: шаг 3, изображение 1 из 2 Logitech Harmony Ultimate Buttons Replacement: шаг 3, изображение 2 из 2
      • Disconnect the wires running from the back cover to the motherboard.
      Спросите у FixBot
    4. Logitech Harmony Ultimate Buttons Replacement: шаг 4, изображение 1 из 1
      • Remove the four 6mm Phillips #0 screws from the battery case.
      Спросите у FixBot
    5. Logitech Harmony Ultimate Buttons Replacement: шаг 5, изображение 1 из 1
      • The battery is still connected to the device via wiring. To free the battery completely, remove the dark plastic piece from the slot with the plastic opening tool. Slowly rotate the dark plastic piece and the battery clockwise until then can be removed from underneath the small circuit board with the USB port.
      • Removing the dark plastic piece from the motherboard takes some patience, as the remote is designed so that the battery will not dislocate under extreme conditions. The small circuit board with the USB port remains connected to the motherboard by six 10 mm pins.
      Спросите у FixBot
    6. Logitech Harmony Ultimate Buttons Replacement: шаг 6, изображение 1 из 1
      • Lift the battery and its case out of the remote.
      • The battery should still be connected to the case with adhesive.
      Спросите у FixBot
    7. Logitech Harmony Ultimate Buttons Replacement: шаг 7, изображение 1 из 2 Logitech Harmony Ultimate Buttons Replacement: шаг 7, изображение 2 из 2
      • Use the plastic opening tool to separate the battery from the case.
      Спросите у FixBot
    1. Logitech Harmony Ultimate Buttons Replacement, Motherboard: шаг 8, изображение 1 из 2 Logitech Harmony Ultimate Buttons Replacement, Motherboard: шаг 8, изображение 2 из 2
      • Remove the four 6mm Phillips #0 screws from the motherboard.
      Спросите у FixBot
    2. Logitech Harmony Ultimate Buttons Replacement: шаг 9, изображение 1 из 2 Logitech Harmony Ultimate Buttons Replacement: шаг 9, изображение 2 из 2
      • There is a flap that connects to the motherboard from the plastic casing. Use fingernails to safely release the flap by flipping the small black buckle upwards.
      • The flap and buckle are underneath the clear yellow piece of tape.
      • Be very careful as damaging this flap could permanently damage your controller.
      Спросите у FixBot
    3. Logitech Harmony Ultimate Buttons Replacement: шаг 10, изображение 1 из 1
      • The motherboard is now safe to remove by sliding and lifting it backwards out of place.
      Спросите у FixBot
    1. Logitech Harmony Ultimate Buttons Replacement, Buttons: шаг 11, изображение 1 из 2 Logitech Harmony Ultimate Buttons Replacement, Buttons: шаг 11, изображение 2 из 2
      • After successfully removing the motherboard, you can easily peel off the buttons from the controller frame.
      Спросите у FixBot
Заключение
5 человек успешно провели ремонт по этому руководству.
Aaron Diaz
Участник с: 08/31/15
728 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 8-1, Eyestone Fall 2015 Участник USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
5 членов
Автор 14 руководств
2 Комментарии к руководству
This is a great demo and it give me much more confidence to tackle the repair. I have some questions. Does the battery need to be removed as I see from your pictures, the motherboard screws are not covered by the battery - or are they? Also, where do you purchase your repair parts? Thank you!
Steve Feldner - Ответить Поделиться
Where do you find the parts? The Logitech website doesn’t have parts for the Ultimate
larrybud2004 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 19
За последние 30 дней: 55
За всё время: 6,822
