Введение
Follow this guide to remove and replace the battery on a Logitech K830 keyboard.
For your safety, discharge the battery below 25% before disassembling your keyboard. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Insert the pointed end of a spudger under the edge of one of the feet.
Push the spudger underneath the foot and pry up to release its adhesive.
Once you can grip the foot with your fingers, peel it up and away from the keyboard to remove it.
Repeat this step for the remaining three feet.
Use a Phillips screwdriver to remove the eight 6.8 mm-long screws securing the upper case to the lower case.
Insert an opening pick about 2 mm into the gap between the upper case and lower case at the bottom-right corner of the keyboard.
Insert the flat end of a spudger about 2 mm into the gap between the upper case and lower case in the bottom right corner of the keyboard.
Rotate the spudger clockwise to release the first clip.
Move the spudger about 3 cm along the keyboard's edge toward the volume buttons.
Rotate the spudger clockwise to release the next clip.
Move the spudger another 3 cm toward the volume buttons and repeat the previous step.
Insert an opening pick about 2 mm into the gap between the upper case and the gray support bar closest to the volume buttons.
Slide the opening pick across the entire length of the keyboard to release the clips on the top edge.
Lift the upper case up by about 2 cm.
Tilt the upper case about 45 degrees so that the keycap letters are upside-down.
Place the top edge of the upper case on your work surface as close to the lower case as possible.
Hold the upper case at about 45 degrees to avoid straining the interconnect cable.
Remove the black tape covering the interconnect cable connector.
Use the pointed end of a spudger to push the interconnect cable connector's locking tab toward the cable.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of blunt tweezers to grip the interconnect cable by the blue section close to the connector.
Pull the interconnect cable out of its connector in the direction of the cable.
Make sure the locking tab is in the unlocked position.
Insert the ribbon cable so that the black line on the cable lines up with the white rectangle's edge closest to the cable.
Use your fingernail to move the locking tab into the locked position.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the battery edge opposite the battery connector.
Wait one minute for the isopropyl alcohol to weaken the adhesive under the battery.
Slowly insert the tip of an opening pick under the top edge of the battery.
Push about half of the opening pick under the battery while slowly lifting up.
Rotate the battery 45 degrees so that the edge closest to the battery connector rests in the battery recess about 1 cm from the connector.
Place two fingers under the bottom side of the battery to support it.
While supporting the battery, disconnect the battery by pulling on the three cables as close to the connector as possible.
Remove the battery from the keyboard.
If there's any alcohol solution remaining in the keyboard, carefully wipe it off with a coffee filter or allow it to air dry before installing your battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Logitech K830 Answers community for help.
4 участников успешно повторили данное руководство.
Один комментарий
Thanks Kyle - absolutely superb instructions - couldn't be clearer.
