Logitech M100 USB Cable Replacement
Выберете то, что вам нужно
  1. Logitech M100 USB Cable Replacement, USB Cable: шаг 1, изображение 1 из 2 Logitech M100 USB Cable Replacement, USB Cable: шаг 1, изображение 2 из 2
    • Not all variants of this mouse require the mouse feet to be taken off for disassembly, but their removal is detailed anyway.
    • Carefully remove the feet of the mouse with an opening pick.
    • Keep track of the mouse feet, as you'll be reapplying them at the end of the guide.
    Спросите у FixBot
    Добавить комментарий
  2. Logitech M100 USB Cable Replacement: шаг 2, изображение 1 из 2 Logitech M100 USB Cable Replacement: шаг 2, изображение 2 из 2
    • Use a Phillips #0 screwdriver to remove the 10mm screws on the bottom of the mouse.
    • Once all screws are removed, use the plastic opening tool to gently pry the mouse apart. This shouldn't take much force.
    Спросите у FixBot
  3. Logitech M100 USB Cable Replacement: шаг 3, изображение 1 из 2 Logitech M100 USB Cable Replacement: шаг 3, изображение 2 из 2
    • Once the mouse is opened, locate the USB cable's 5-pin connector, which is plugged directly into the mouse's mainboard.
    • Take note of the position and route that the USB cable takes before removal. The replacement cable must follow the same route when inserted.
    • Using a plastic opening tool, gently remove the 5-pin connector from the mainboard.
    Спросите у FixBot
  4. Logitech M100 USB Cable Replacement: шаг 4, изображение 1 из 2 Logitech M100 USB Cable Replacement: шаг 4, изображение 2 из 2
    • Take the replacement USB cable and connect it to the mainboard.
    Спросите у FixBot
  5. Logitech M100 USB Cable Replacement: шаг 5, изображение 1 из 2 Logitech M100 USB Cable Replacement: шаг 5, изображение 2 из 2
    • Ensure that the 5-pin connector is fully seated into its slot on the mainboard. You may want to use a spudger to apply pressure onto it.
    • Using a plastic opening tool, route the cable through the case in the same way that was noted in Step 3.
    Спросите у FixBot
  6. Logitech M100 USB Cable Replacement: шаг 6, изображение 1 из 1
    • After re-assembling the mouse, don't forget to reattach the mouse feet onto their correct locations on the bottom of the mouse.
    Спросите у FixBot
Заключение
To reassemble, follow the steps in reverse order.
4 человек успешно провели ремонт по этому руководству.
Jake Janicke
Участник с: 10/26/17
161 Репутация
1 руководство автора
Команда
DePaul University, Team S1-G5, Dush Fall 2017 Участник DePaul University, Team S1-G5, Dush Fall 2017
DPU-DUSH-F17S1G5
2 членов
Автор 1 руководств
1 Комментарий к руководству
Removing the mouse feet is completely unnecessary, as there are no screws underneath the feet.
Andy Joonseo Bae - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 11
За последние 30 дней: 37
За всё время: 6,546
