Logitech M215 Battery Replacement
Выберете то, что вам нужно
  1. Logitech M215 Battery Replacement, Remove the battery cover: шаг 1, изображение 1 из 3 Logitech M215 Battery Replacement, Remove the battery cover: шаг 1, изображение 2 из 3 Logitech M215 Battery Replacement, Remove the battery cover: шаг 1, изображение 3 из 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
    Спросите у FixBot
    Добавить комментарий
  2. Logitech M215 Battery Replacement, Remove old battery: шаг 2, изображение 1 из 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
    Спросите у FixBot
Заключение
28 человек успешно провели ремонт по этому руководству.
Hannah Pate
Участник с: 01/30/15
1 742 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 1-1, Watkins Winter 2015 Участник USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 членов
Автор 28 руководств
10 Комментарии к руководству
I disassembled this exactly as stated and now I can't get the cover back on?
Rei Peterson - Ответить Поделиться
I am a electronic technologist and this is a poor design for a mouse. No wonder the later version is different.
Joseph Wonderless - Ответить Поделиться
Thanks for the information. It worked perfectly for me. Easy removal. Images and instructions were very helpful.
Tracy Moore - Ответить Поделиться
The green battery light went on, although the lazar light did not. What should I do?
Susan Petho - Ответить Поделиться
well this is a bit horrible, because i don’t have an extra AA battery.. and i have a M325, but the battery life is dead..
Diana Lee - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 63
За последние 30 дней: 231
За всё время: 124,235
