Logitech M215 Scroll Wheel Replacement
Выберете то, что вам нужно
  1. Logitech M215 Scroll Wheel Replacement, Remove the battery cover: шаг 1, изображение 1 из 3 Logitech M215 Scroll Wheel Replacement, Remove the battery cover: шаг 1, изображение 2 из 3 Logitech M215 Scroll Wheel Replacement, Remove the battery cover: шаг 1, изображение 3 из 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
    Спросите у FixBot
    Добавить комментарий
  2. Logitech M215 Scroll Wheel Replacement, Remove old battery: шаг 2, изображение 1 из 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
    Спросите у FixBot
  3. Logitech M215 Scroll Wheel Replacement, Button Plate: шаг 3, изображение 1 из 2 Logitech M215 Scroll Wheel Replacement, Button Plate: шаг 3, изображение 2 из 2
    • Use your fingernail to carefully remove the two skid stickers from the fat (non-button) end of the bottom of the mouse to reveal two Philips head screws. Remove these, then unclip the bottom cover. Don't get the sticky dusty. Now remove buttons; they're both attached by one 0.5mm Phillips head screw. It is located in the center of the top cover.
    Спросите у FixBot
  4. Logitech M215 Scroll Wheel Replacement, Pry off buttons: шаг 4, изображение 1 из 2 Logitech M215 Scroll Wheel Replacement, Pry off buttons: шаг 4, изображение 2 из 2
    • The button are now only attached by a small overhang near the front. You will need to use the pry tool to push the button plate off of this overhang as shown.
    • The button plate should be able to be completely removed at this point.
    Спросите у FixBot
  5. Logitech M215 Scroll Wheel Replacement, Scroll Wheel: шаг 5, изображение 1 из 1
    • Use the prying tool to remove the scroll wheel. The wheel is held in place by two pegs which stick into the plastic holder.
    Спросите у FixBot
Заключение
9 человек успешно провели ремонт по этому руководству.
Hannah Pate
Участник с: 01/30/15
1 742 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 1-1, Watkins Winter 2015 Участник USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 членов
Автор 28 руководств
6 Комментарии к руководству
glad I was able to find this info on disassembly. Gave it a good cleaning and works better than it did before. Had the Phillips screwdriver. and used another small screwdriver and a small pocket knife to pry with. Be gentle - doesn’t look like it would take much force to break those plastic bits.
carmenanddave - Ответить Поделиться
Thanks! Mouse wheel windows were blocked by lint.
levensonjb - Ответить Поделиться
Very useful. Cleaned coffee out of mouse wheel spokes/windows and off of chipboard. Works better than before. Thanks!
OGrady Watson - Ответить Поделиться
Probably the BROWN stuff wasn’t coffee, I too cleaned the spokes/windows. the brown stuff is oil from out hands which lands on scroll wheel, then by heat gets transferred to the spokes. touch a finger on the mirror, the fingerprint on the mirror is because of OIL on hands. it is the same oil in that mouse wheel spokes.
tejaswin_jain - Ответить Поделиться
There is a spring here connected to the wheel. Seems to be the thing to give tactical feedback when scrolling. It fell out when I took out the wheel not 100% how to put it back
Dan Molnar - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 23
За последние 30 дней: 81
За всё время: 14,597
