Введение
When the batteries in your Logitech POP Mouse die, it is difficult to get any work done. Here's how to swap the batteries in your mouse.
This guide is for the 910-007408 and 910-007409 models of the Logitech POP Mouse.
Flip the mouse over so the bottom is facing up.
Slide the power switch off.
Flip the mouse back over so it is facing upright.
Press gently on the white button and pull towards the bottom of the mouse to pull the top cover off.
Press down on the part of the battery closest to the front of the mouse to pop the backend of it upwards, and then gently pull the battery out.
Insert the battery into the slot.
Place the cover plate over the mouse, and the magnetic connectors should slide the cover into place.
Turn your mouse back on using the same switch as earlier. If everything was done correctly, your mouse should be good as new!
