Выберете то, что вам нужно
Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
Repeat for the bottom of the speaker and pry the casing open with your fingers.
Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
Do the same for the two black 7 mm screws.
Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
With the switch plate disconnected, remove it and your device should now look like this.
With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
With the screws removed, pry open the casing to be able to get to the components inside.
With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
34 человек успешно провели ремонт по этому руководству.
30 Комментарии к руководству
What battery is required?
You've got to be joking - so you spend £100 on a speaker and then need a degree in electrical engineering to replace the battery - what a load of s***e
exactly, I agree
I replaced the battery in mine. It took about an hour and it was easy, while the instructions appear complicated, undoing a few screws and folding back some tabs took only a few seconds. Before I replaced the battery my Boom had failed completely. Nothing I tried kicked the dead battery into working again, so I had two choices. Try replacing the battery or chucking it in the bin. So I bought a battery and had a go. I read up and had the right tools, and as luck favours the prepared, I was successful. The only warning I can think of is that out of the box the Boom is water resistant I believe, but post repair, I doubt it’s water resistant now.
Don't pry open the entire thing. Open the side with the d-ring, there should be 4 screws like in the pic above and access to battery directly under that. There's instructions for changing battery in the box.
