Введение
Is your computer running slow, or do you need more memory? Use this guide to replace the RAM in your device.
Выберете то, что вам нужно
Find the unlock tab located on the upper right side of the device, then slide it to the right.
Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
3 человек успешно провели ремонт по этому руководству.
