Введение
Accessing the RAM is easy and requires no tools. Use this guide to add or replace RAM for your Mac Pro.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Remove the side panel of the Mac Pro.
Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
22 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
What is the name/or type of memory chip to use in the MacPro 2008.
Hi Curtis, hope you found the RAM type ok.
Basically server RAM, ECC, 667Mhz, FB always in Pairs.
Retired Apple, PC etc engineer.
