Введение
Use this guide to replace the USB-C board in a 2019 MacBook Air.
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
Before the battery can be fully disconnected, the battery disconnect button needs to be held down. There is a gold button just above the battery socket, along with a small LED much like the 12” machines. Once this has been held down and the LED has switched off it is safe to remove the battery.
This seems like an important step?
Also, seems like this should be done after the battery is disconnected, not before? Otherwise, wouldn’t the battery re-charge it?
What if the white LED dosent light up after pressing the yellow button again?
Iron05 -
I just performed this repair on my late 2018 mac air. I did click the gold button but saw no LED illuminated or otherwise. Question- after reassembly does the button get pressed again to connect the battery? Please clarify if this button is to be pressed and if it needs pressing again after the repair.
All said - I pressed again after the battery connector clicked, assembled the back and all worked perfectly. The original issue was one dead port (no charge, no communication). The battery charge lightening bold icon was acting funny too. Genuis bar guy in Naperville said it was likely a logic board too. But it was not. The port was apparently confusing the logic board with regards to the charge function. Thanks Adam for saving me $440 and sending my computer back to Apple. I am 71 yrs young - who says an old dog can’t learn new tricks with good training!!
Use a T3 Torx driver to remove the two 1.4 mm screws securing the USB-C connector bracket.
Remove the USB-C connector bracket.
Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
7 участников успешно повторили данное руководство.
Комментариев: 3
I bought a new Macbook air in 2019 but I didn’t open it until September of 2020. While activating and upgrade the operating system. My laptop shows a dying battery. Eventually, it is not powering up or startup at all. I want to pay it off before I use it and I am not aware of the warranty beginning on the same day I placed the order with BestBuy. I replaced the battery from eBay and didn’t work. Now I am stuck with a brick that I don’t know what to do with it. Replacing the USB c port resolves the problem of no power at all?
Instructions were very clear with the exception of the re-attachment of the USB-C board. There is a metal "grille" on both the USB-C board and the computer; are they supposed to "click" together? I aligned them geometrically, but there was no positive feedback when I pressed them together. - David
Just finished mine without a problem. I've used iFixit 64 bit set from Home Depot. This saved $400 repair. Thanks!
If the first thing you do is disconnect the battery, is it really an issue if you don’t (or can’t) disable auto-boot?
maccentric - Ответить
