MacBook Core Duo Front Display Bezel Replacement
Выберете то, что вам нужно
    1. MacBook Core Duo Front Display Bezel Replacement, Battery: шаг 1, изображение 1 из 1
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      Спросите у FixBot
      Добавить комментарий
    2. MacBook Core Duo Front Display Bezel Replacement: шаг 2, изображение 1 из 1
      • Lift the battery out of the computer.
      Спросите у FixBot
    1. MacBook Core Duo Front Display Bezel Replacement, Memory Cover: шаг 3, изображение 1 из 1
      • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover.
      • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
      Спросите у FixBot
    2. MacBook Core Duo Front Display Bezel Replacement: шаг 4, изображение 1 из 1
      • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
      Спросите у FixBot
    1. MacBook Core Duo Front Display Bezel Replacement, Upper Case: шаг 5, изображение 1 из 1
      • Remove the following 3 screws:
      • One 11 mm Phillips #00 in the middle of the case.
      • Two 14.5 mm Phillips #00.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle.
      Спросите у FixBot
    2. MacBook Core Duo Front Display Bezel Replacement: шаг 6, изображение 1 из 1
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
      • One 4 mm Phillips #00 on the right side.
      • When reinstalling these screws, press gently on the lower case to line up the screw holes.
      • These screws easily strip, so be careful while taking these particular screws out.
      Спросите у FixBot
    3. MacBook Core Duo Front Display Bezel Replacement: шаг 7, изображение 1 из 1
      • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      Спросите у FixBot
    4. MacBook Core Duo Front Display Bezel Replacement: шаг 8, изображение 1 из 1
      • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
      Спросите у FixBot
    5. MacBook Core Duo Front Display Bezel Replacement: шаг 9, изображение 1 из 1
      • Remove the following 4 screws from the back of the computer:
      • Two 7 mm shouldered Phillips on the far sides.
      • Two 10.5 mm Phillips toward the center.
      • Do not over-tighten these; you can cause the case to distort.
      Спросите у FixBot
    6. MacBook Core Duo Front Display Bezel Replacement: шаг 10, изображение 1 из 1
      • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
      • It is not necessary to remove the similar screws on the other side of the computer.
      Спросите у FixBot
    7. MacBook Core Duo Front Display Bezel Replacement: шаг 11, изображение 1 из 1
      • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
      • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
      • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
      Спросите у FixBot
    8. MacBook Core Duo Front Display Bezel Replacement: шаг 12, изображение 1 из 1
      • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
      • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
      • Do not pry from the bottom or the top, but from the sides.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      Спросите у FixBot
    1. MacBook Core Duo Front Display Bezel Replacement, Optical Drive: шаг 13, изображение 1 из 1
      • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
      Спросите у FixBot
    2. MacBook Core Duo Front Display Bezel Replacement: шаг 14, изображение 1 из 1
      • Remove the two Phillips screws from the front edge of the optical drive.
      • The shorter screw (3 mm) is recessed nearest the RAM modules. The other is 3.5 mm.
      Спросите у FixBot
    3. MacBook Core Duo Front Display Bezel Replacement: шаг 15, изображение 1 из 1
      • Disconnect the orange optical drive ribbon cable from the logic board.
      Спросите у FixBot
    4. MacBook Core Duo Front Display Bezel Replacement: шаг 16, изображение 1 из 1
      • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
      Спросите у FixBot
    5. MacBook Core Duo Front Display Bezel Replacement: шаг 17, изображение 1 из 1
      • Disconnect the (once again) newly-revealed hard drive cable.
      Спросите у FixBot
    6. MacBook Core Duo Front Display Bezel Replacement: шаг 18, изображение 1 из 1
      • Peel up the foil tape between the fan and the optical drive.
      • Remove the 8.5 mm Phillips screw securing the display data cable to the metal framework.
      Спросите у FixBot
    7. MacBook Core Duo Front Display Bezel Replacement: шаг 19, изображение 1 из 1
      • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
      Спросите у FixBot
    8. MacBook Core Duo Front Display Bezel Replacement: шаг 20, изображение 1 из 1
      • Remove the 2.8 mm Phillips screw securing the optical drive.
      • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
      • Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
      • After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
      Спросите у FixBot
    9. MacBook Core Duo Front Display Bezel Replacement: шаг 21, изображение 1 из 1
      • Lift the Bluetooth antenna board from the right side of the optical drive.
      Спросите у FixBot
      • Deroute the hard drive cable from along the front of the optical drive.
      Спросите у FixBot
    10. MacBook Core Duo Front Display Bezel Replacement: шаг 23, изображение 1 из 1
      • Lift the front edge of the optical drive and slide it up and out of the computer.
      Спросите у FixBot
    1. MacBook Core Duo Front Display Bezel Replacement, C-Channel: шаг 24, изображение 1 из 1
      • Two 3 mm Phillips near the right speaker.
      • One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
      • Be careful not to over-tighten the screw above the subwoofer too tight or the plastic could crack.
      Спросите у FixBot
    2. MacBook Core Duo Front Display Bezel Replacement: шаг 25, изображение 1 из 1
      • Lift the right speaker out of its housing and set it to the side.
      Спросите у FixBot
    3. MacBook Core Duo Front Display Bezel Replacement: шаг 26, изображение 1 из 1
      • Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
      Спросите у FixBot
    1. MacBook Core Duo Front Display Bezel Replacement, Display: шаг 27, изображение 1 из 1
      • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
      • Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
      Спросите у FixBot
    2. MacBook Core Duo Front Display Bezel Replacement: шаг 28, изображение 1 из 1
      • Lift up on the black right speaker cable with one hand, and deroute the silver microphone cable from the silver metal clip just above the right RAM slot.
      Спросите у FixBot
    3. MacBook Core Duo Front Display Bezel Replacement: шаг 29, изображение 1 из 1
      • Deroute the silver microphone cable and gray display data cable from the tabs at the bottom of the subwoofer.
      Спросите у FixBot
    4. MacBook Core Duo Front Display Bezel Replacement: шаг 30, изображение 1 из 1
      • Remove the single 3.2 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
      Спросите у FixBot
    5. MacBook Core Duo Front Display Bezel Replacement: шаг 31, изображение 1 из 1
      • Disconnect the two antenna cables from the Airport card, and the black inverter cable from the logic board. (Pull vertically on all three.)
      Спросите у FixBot
    6. MacBook Core Duo Front Display Bezel Replacement: шаг 32, изображение 1 из 1
      • Remove the following 2 screws from the right hinge mount:
      • One 6 mm Phillips on the left side of the hinge mount.
      • One 10 mm Phillips on the right side of the hinge mount.
      • Lift the right hinge mount out of the computer.
      Спросите у FixBot
    7. MacBook Core Duo Front Display Bezel Replacement: шаг 33, изображение 1 из 1
      • Hold the display with one hand while removing the screws from the left hinge mount.
      • Remove the following 3 screws from the left hinge mount:
      • One 6 mm smaller diameter Phillips from the right side.
      • One 6 mm larger diameter Phillips from the middle.
      • One 10 mm Phillips from the left side.
      • Lift the left hinge mount out of the computer.
      Спросите у FixBot
    8. MacBook Core Duo Front Display Bezel Replacement: шаг 34, изображение 1 из 1
      • Grasp the display assembly on either side, and lift it up and out of the computer.
      Спросите у FixBot
    1. MacBook Core Duo Front Display Bezel Replacement, Front Display Bezel: шаг 35, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      Plastic Cards
      $2.99
      • The following steps should be identical for both white and black MacBooks.
      • Use a thin plastic card to release the tabs and their clips holding the front display bezel to the display assembly. There are five tabs along the left side of the display bezel.
      • You may find some display bezels are easier to remove if you work from their inside edges, directly adjacent to/above the LCD panel.
      • Don't use a card that cannot be replaced if damaged. The clips can be difficult to remove and the card can bend and break, rendering it useless.
      Спросите у FixBot
    2. MacBook Core Duo Front Display Bezel Replacement: шаг 36, изображение 1 из 1
      • Continue to free the tabs along the the top edge of the display assembly.
      • Be careful when working near the iSight camera.
      Спросите у FixBot
    3. MacBook Core Duo Front Display Bezel Replacement: шаг 37, изображение 1 из 1
      • Next, free the five tabs securing the display bezel on the right side.
      Спросите у FixBot
    4. MacBook Core Duo Front Display Bezel Replacement: шаг 38, изображение 1 из 2 MacBook Core Duo Front Display Bezel Replacement: шаг 38, изображение 2 из 2
      • Lift up the front display bezel from the top and use your plastic card to free the tabs along the bottom edge of the display bezel.
      • Make sure that your card is between the metal frame around the LCD panel and the display bezel and not touching the LCD panel itself.
      • After freeing all holding tabs, lift the front display bezel away from the display assembly.
      • When reinstalling the front display bezel onto the display housing, you may find it easier to get the tabs and clips to connect if you push on the four sides of the bezel in this order: top, bottom, then the sides (left or right). You may have to apply extra pressure along the bottom side of the bezel to get it to snap into place firmly.
      Спросите у FixBot
    5. MacBook Core Duo Front Display Bezel Replacement: шаг 39, изображение 1 из 2 MacBook Core Duo Front Display Bezel Replacement: шаг 39, изображение 2 из 2
      • Sometimes when removing the front display bezel, the retaining clips that should remain captive in the LCD brackets come out with the front display bezel. Follow this and the next step to transfer the clips back to the LCD bracket.
      • Use a metal spudger or another thin tool to carefully pry the gray plastic clips off the tabs molded into the front display bezel. A 0.8mm flat screwdriver may be useful for this step. You may find that it's easier to remove some of these clips by prying up on their long sides.
      • Be careful, as the clips are made of thin plastic and are inherently delicate.
      Спросите у FixBot
    6. MacBook Core Duo Front Display Bezel Replacement: шаг 40, изображение 1 из 2 MacBook Core Duo Front Display Bezel Replacement: шаг 40, изображение 2 из 2
      • Insert one end of the retaining clip beneath the edge of its recess cut into the LCD bracket.
      • Use the edge of a spudger to push the short hook tab on the underside of the other end of the retaining clip into the recess cut into the LCD bracket.
      • The second picture shows a retaining clip properly installed.
      • You may find it easier to get the short hook tabs on the underside of each end of the clip to fit down inside their cutout in the LCD bracket by first very slightly bending down the two ends of the clip, but be careful not to bend the clips too much--only a slight bend is needed, and too much force will break them.
      Спросите у FixBot
Заключение
30 человек успешно провели ремонт по этому руководству.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 632 руководств
4 Комментарии к руководству
This may be a lame question but is it completely necessary to do steps 1-34? Can we simply remove the bezel with out taking off the display?
tkn77 - Ответить Поделиться
You're right, most of these steps are irrelevant. You can easily just pop it off. You can do 36-40 without taking apart the whole computer. just start on the lower sides. I did it yesterday. It's really easy.
Allison - Ответить Поделиться
I don't mean to insult this guide. But you can definitely take the bezel screen frame off without taking apart the whole computer. It's not attached to anything other than the bezels. Just start at the bottom sides and go from there. This guide could definitely be simplified. You just need to do 36-40
You are right I just did mine yesterday, unknowingly with no prior knowledge, I fix a new display bezel without tempering with the top Case.
Cent Ci - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 11
За последние 30 дней: 44
За всё время: 68,581
