MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement
Выберете то, что вам нужно
  1. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.7 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    Спросите у FixBot
    Добавить комментарий
  2. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Open a gap using a suction cup: шаг 2, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Open a gap using a suction cup: шаг 2, изображение 2 из 2
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
    Спросите у FixBot
  3. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the clips: шаг 3, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the clips: шаг 3, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the clips: шаг 3, изображение 3 из 3
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
    Спросите у FixBot
  4. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 4, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 4, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 4, изображение 3 из 3
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
    Спросите у FixBot
  5. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 5, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 5, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 5, изображение 3 из 3
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
    Спросите у FixBot
  6. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 6, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 6, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 6, изображение 3 из 3
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
    Спросите у FixBot
  7. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the lower case: шаг 7, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the lower case: шаг 7, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the lower case: шаг 7, изображение 3 из 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
    Спросите у FixBot
  8. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Uncover the battery connector: шаг 8, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Uncover the battery connector: шаг 8, изображение 2 из 2
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
    Спросите у FixBot
  9. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 9, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 9, изображение 2 из 2
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
    Спросите у FixBot
  10. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 10, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 10, изображение 2 из 2
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
    Спросите у FixBot
  11. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 11, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 11, изображение 2 из 2
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
    Спросите у FixBot
  12. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 12, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 12, изображение 2 из 2
    • Fold the battery board data cable to the side and out of the way.
    Спросите у FixBot
  13. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 13, изображение 1 из 1
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
    Спросите у FixBot
  14. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Disconnect the battery: шаг 14, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Disconnect the battery: шаг 14, изображение 2 из 2
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
    Спросите у FixBot
  15. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the trackpad connector screws: шаг 15, изображение 1 из 1
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
    Спросите у FixBot
  16. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 16, изображение 1 из 1
    • Remove the trackpad cable connector bracket with a pair of tweezers.
    Спросите у FixBot
  17. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Disconnect the trackpad: шаг 17, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Disconnect the trackpad: шаг 17, изображение 2 из 2
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
    Спросите у FixBot
  18. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Heat the trackpad cable: шаг 18, изображение 1 из 1
    • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
    Спросите у FixBot
  19. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Peel up the trackpad cable: шаг 19, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Peel up the trackpad cable: шаг 19, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Peel up the trackpad cable: шаг 19, изображение 3 из 3
    • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
    • Do not fold or tear the cable.
    Спросите у FixBot
  20. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the trackpad screws: шаг 20, изображение 1 из 1
    • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
    • Two 4.3 mm screws
    • Eight 5.8 mm screws
    Спросите у FixBot
  21. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 21, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 21, изображение 2 из 2
    • Swing the display open slightly to access the trackpad.
    • Carefully thread the trackpad ribbon cable out through the hole in the MacBook Pro's frame.
    Спросите у FixBot
  22. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 22, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 22, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 22, изображение 3 из 3
    • Remove the trackpad assembly.
    • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
    Спросите у FixBot
  23. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Unscrew the battery board: шаг 23, изображение 1 из 1
    • Use a T5 Torx driver to remove the two 3.2 mm screws from the battery board.
    Спросите у FixBot
  24. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect the display and keyboard: шаг 24, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect the display and keyboard: шаг 24, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect the display and keyboard: шаг 24, изображение 3 из 3
    • The liquid adhesive remover provided in your kit can cause damage if it contacts the MacBook Pro's display or keyboard.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
    • Additionally, use some tape and/or foil to seal off the area under the trackpad. Optionally, you may also layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
    Спросите у FixBot
  25. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect the speakers: шаг 25, изображение 1 из 1
    • Before removing the battery, it's important to protect the speakers on either side. The speakers are glued down just like the battery—so if the liquid adhesive remover gets under the speakers, they may come loose and rattle after your repair.
    • Cut a length of packing tape or painter's tape, and slide one edge between the battery and the speaker on the left side.
    Спросите у FixBot
  26. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 26, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 26, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 26, изображение 3 из 3
    • Press all along the edge of the tape with your spudger to stick it securely to the MacBook Pro's aluminum case, sealing off the speaker from the battery.
    • Be careful not to poke or puncture the battery.
    • Fold the tape over and lightly adhere it to the speaker to keep it out of the way.
    • The foam bumpers on top of the speaker may tear when peeling the tape off. Don't press the tape directly onto the bumpers.
    Спросите у FixBot
  27. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 27, изображение 1 из 1
    • Repeat the previous two steps on the opposite side in order to seal off the other speaker from the battery.
    Спросите у FixBot
  28. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the right edge: шаг 28, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the right edge: шаг 28, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the right edge: шаг 28, изображение 3 из 3
    • To control the flow of adhesive remover and direct it away from the speaker, raise the right edge of your MacBook Pro a few inches using a book or foam block.
    Спросите у FixBot
  29. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect your eyes and skin: шаг 29, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Protect your eyes and skin: шаг 29, изображение 2 из 2
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
    Спросите у FixBot
  30. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Open the adhesive remover: шаг 30, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Open the adhesive remover: шаг 30, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Open the adhesive remover: шаг 30, изображение 3 из 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
    Спросите у FixBot
  31. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply the adhesive remover: шаг 31, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply the adhesive remover: шаг 31, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply the adhesive remover: шаг 31, изображение 3 из 3
    • Apply a few drops of adhesive remover underneath the far right battery cell.
    • You don't need to use very much—the small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait about two minutes for the adhesive remover to penetrate and soften the battery adhesive before you proceed to the next step.
    Спросите у FixBot
  32. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the outside right battery cell: шаг 32, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the outside right battery cell: шаг 32, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the outside right battery cell: шаг 32, изображение 3 из 3
    Plastic Cards
    $2.99
    • After a couple minutes, insert one corner of a plastic card underneath the far right battery cell, starting from the front edge.
    • This shouldn't require much force. If you have trouble, apply more adhesive remover and give it 2-3 additional minutes to penetrate.
    • Try not to deform the battery. A damaged battery can leak dangerous chemicals and/or catch fire.
    • Wiggle the card from side to side and slide it all the way under the battery cell.
    • Lift to fully separate the adhesive, but don't try to remove the battery cell yet.
    • Leave the plastic card temporarily underneath the cell to prevent it from re-adhering while you continue.
    Спросите у FixBot
  33. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Alternative: separate the battery cell with floss: шаг 33, изображение 1 из 1
    • If you have difficulty getting the card underneath any of the battery cells, try working a piece of floss or wire underneath the battery cell. Pull it side-to-side in a sawing motion to separate the adhesive.
    • Wear thick gloves or wrap the floss around a couple of driver handles so as not to hurt your fingers.
    Спросите у FixBot
  34. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the left edge: шаг 34, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the left edge: шаг 34, изображение 2 из 2
    • Repeat the last few steps to separate the far left battery cell.
    • Begin by elevating the left side of the MacBook Pro to direct the flow of adhesive remover away from the speaker.
    Спросите у FixBot
  35. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: шаг 35, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: шаг 35, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: шаг 35, изображение 3 из 3
    • Apply a few drops of adhesive remover under the far left battery cell, and wait about two minutes for it to penetrate.
    Спросите у FixBot
  36. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the outer left cell: шаг 36, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the outer left cell: шаг 36, изображение 2 из 2
    • Slide one corner of a plastic card underneath the far left battery cell, and carefully separate the adhesive holding it in place.
    Спросите у FixBot
  37. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Elevate the back edge: шаг 37, изображение 1 из 1
    • Next, raise the back edge of your MacBook Pro to direct the flow of adhesive remover away from the keyboard/logic board area.
    Спросите у FixBot
  38. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: шаг 38, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: шаг 38, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Apply adhesive remover: шаг 38, изображение 3 из 3
    • Apply a few drops of adhesive remover under each of the remaining three battery cells.
    • There are openings in the aluminum case underneath these cells, so some of the adhesive remover may leak out instead of penetrating underneath the battery.
    • Be mindful of leaks, and apply more adhesive remover in the following steps if needed.
    • Wait about two minutes before you continue.
    Спросите у FixBot
  39. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner left cell: шаг 39, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner left cell: шаг 39, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner left cell: шаг 39, изображение 3 из 3
    • The remaining two smaller battery cells each sit on a slightly raised portion of the MacBook's aluminum frame.
    • Slide a plastic card all the way underneath the far left battery cell—which you already separated in the previous steps—and then insert it carefully between the remaining left-side battery cell and the MacBook Pro's aluminum case.
    Спросите у FixBot
  40. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 40, изображение 1 из 2 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement: шаг 40, изображение 2 из 2
    • Use your plastic card to fully separate the remaining battery cell on the left side.
    • Take care to not pry against the logic board.
    • Leave your plastic card in place temporarily to prevent the left-side battery cells from re-adhering.
    Спросите у FixBot
  41. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner right cell: шаг 41, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner right cell: шаг 41, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the inner right cell: шаг 41, изображение 3 из 3
    • Repeat the previous two steps to separate the remaining battery cell on the right.
    Спросите у FixBot
  42. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the middle cells: шаг 42, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the middle cells: шаг 42, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Separate the middle cells: шаг 42, изображение 3 из 3
    • The final battery cells can be more difficult to remove. If needed, apply more adhesive remover to make the job easier.
    • Slide the corner of one of your plastic cards underneath the top edge of one of the cells and then work it underneath the other cell.
    • Wiggle the card from side to side and slide it underneath the battery cells to fully separate the adhesive holding them in place.
    Спросите у FixBot
  43. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the battery: шаг 43, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the battery: шаг 43, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Remove the battery: шаг 43, изображение 3 из 3
    • Before you remove the battery, ensure that the battery connector is sufficiently raised and not in the way of the battery board.
    • Remove the battery.
    • Before installing a new battery, remove all remaining adhesive from the MacBook Pro's case.
    • Peel off any large strips of adhesive using tweezers or gloved fingers.
    • Scrape away any remaining chunks of adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction (not back and forth) until the chassis is clean and ready for your new battery.
    • This can take quite a bit of work, so be patient.
    • When you're done, carefully remove the protective tape from the speakers.
    Спросите у FixBot
  44. MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Battery installation: шаг 44, изображение 1 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Battery installation: шаг 44, изображение 2 из 3 MacBook Pro 13" Four Thunderbolt Ports 2020 Battery Replacement, Battery installation: шаг 44, изображение 3 из 3
    Tesa 61395 Tape
    $25.95
    • Double-check the fit and alignment of your new battery before sticking it down.
    • Be mindful of the battery data cable and make sure it doesn't get pinched or trapped under the battery board.
    • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
    • Carefully position the battery and set it into place.
    • Place the battery close to the logic board so the trackpad cable can reach its connector.
    • Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
30 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
167 338 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 28 236 руководств
7 Комментарии к руководству
Thank you I don’t own this but this repair was easy to understand and well written. Keep up the good work!🤓😆🦆
dan g - Ответить Поделиться
Thank you for a great tutorial. Helped me a lot to replace the battery on a MacBook Pro.
Juan Rivera - Ответить Поделиться
Thanks for the very useful tutorial which was very helpful when replacing 2020 MacBook batteries.
David Rossi - Ответить Поделиться
Great video: well-explained and easy to follow!
Erick Pineda - Ответить Поделиться
Thank you for an excellent guide. Without this guide the battery replacement would have been very challenging and uncertain. I would like to add a few errata:
1. In Step 44 - Battery Replacement - be sure to align the two Battery Board screw holes when replacing the battery
2. The glue remover provided in the iFixit tools kit came in a different bottle than shown in the picture. The bottle has a larger point and doesn't fit well in the gaps next to the battery. It would have been cleaner and safer to transfer the glue remover to a small bottle with a fine tip before using it.
3. Step 7 - Replacing the lower case - my case overlapped the frame a bit when inserting it into the rear sliding clips. It apparently was a bit flattened and needed to be gently bowed as it was inserted.
David - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 59
За последние 7 дней: 379
За последние 30 дней: 1,727
За всё время: 70,097
