MacBook Pro 15" Touch Bar 2018 Screen Replacement
Выберете то, что вам нужно
    1. MacBook Pro 15" Touch Bar 2018 Screen Replacement, Disable Auto Boot: шаг 1, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement, Disable Auto Boot: шаг 1, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement, Disable Auto Boot: шаг 1, изображение 3 из 3
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
      Спросите у FixBot
      Добавить комментарий
    1. MacBook Pro 15" Touch Bar 2018 Screen Replacement, Lower Case: шаг 2, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement, Lower Case: шаг 2, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      Magnetic Project Mat
      $19.95
      • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
      • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
      • Four 4.7 mm screws
      • Two 6.6 mm screws
      • Note how the screws come out at a slight angle—you must reinstall them the same way.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Спросите у FixBot
    2. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 3, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 3, изображение 2 из 2
      • Press a suction handle into place near the front edge of the lower case, between the screw holes.
      • Pull up on the suction handle just enough to open a small gap under the lower case.
      Спросите у FixBot
    3. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 4, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 4, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 4, изображение 3 из 3
      • Slide the corner of an opening pick into the gap you just created underneath the lower case.
      • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
      • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
      Спросите у FixBot
    4. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 5, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 5, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 5, изображение 3 из 3
      • Repeat the previous step on the other side, using an opening pick to release the second clip.
      Спросите у FixBot
    5. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 6, изображение 1 из 1
      • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
      • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
      • Don't lift more than an inch or so, and don't try to remove the lower case yet.
      Спросите у FixBot
    6. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 7, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 7, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 7, изображение 3 из 3
      • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
      • Pull first at one corner, then the other.
      • Pull to the side—not up.
      • This may require a lot of force.
      Спросите у FixBot
    7. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 8, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 8, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 8, изображение 3 из 3
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
      • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
      Спросите у FixBot
    1. MacBook Pro 15" Touch Bar 2018 Screen Replacement, Battery Connector: шаг 9, изображение 1 из 1
      • Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
      • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
      • If the cover doesn't seat securely during reassembly, try rotating it 180 degrees. It must be oriented correctly in order for the adhesive pads underneath to contact the board screws.
      Спросите у FixBot
    2. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 10, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 10, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 10, изображение 3 из 3
      • Peel back any tape covering the battery board data cable connector.
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
      Спросите у FixBot
    3. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 11, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 11, изображение 2 из 2
      • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
      • Slide parallel to the logic board, in the direction of the cable.
      Спросите у FixBot
    4. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 12, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 12, изображение 2 из 2
      • Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
      Спросите у FixBot
    5. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 13, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 13, изображение 2 из 2
      • Slide the battery board data cable out of its socket on the battery board, and remove it completely.
      • Take care not to install this cable backwards or upside-down. When installed correctly, the white liquid indicator sticker should face up, positioned directly over the battery power connector screw.
      Спросите у FixBot
    6. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 14, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 14, изображение 2 из 2
      • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
      Спросите у FixBot
    7. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 15, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 15, изображение 2 из 2
      • Use a spudger to lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
      Спросите у FixBot
    1. MacBook Pro 15" Touch Bar 2018 Screen Replacement, Screen: шаг 16, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement, Screen: шаг 16, изображение 2 из 2
      • Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
      • Remove the display board flex cover.
      Спросите у FixBot
    2. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 17, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 17, изображение 2 из 2
      • Use a T3 Torx driver to remove the two 1.7 mm screws securing the bracket for the display board cable connector.
      • Remove the display board cable connector bracket.
      Спросите у FixBot
    3. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 18, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 18, изображение 2 из 2
      • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
      Спросите у FixBot
    4. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 19, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 19, изображение 2 из 2
      • Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
      Спросите у FixBot
    5. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 20, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 20, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 20, изображение 3 из 3
      • Remove both hinge covers.
      Спросите у FixBot
    6. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 21, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 21, изображение 2 из 2
      • Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
      Спросите у FixBot
    7. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 22, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 22, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 22, изображение 3 из 3
      • Disconnect all three antenna cables by prying each one straight up from its socket.
      • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
      • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
      Спросите у FixBot
    8. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 23, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 23, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 23, изображение 3 из 3
      • Use a T5 Torx driver to remove the four 3.3 mm screws securing the display board.
      • Before reinstalling these screws:
      • Make sure the display board flex cable lies on top of the board, not trapped underneath.
      Спросите у FixBot
    9. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 24, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 24, изображение 2 из 2
      • Use a P2 Pentalobe driver to remove the sixteen 1.5 mm screws securing the antenna assembly.
      Спросите у FixBot
    10. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 25, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 25, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 25, изображение 3 из 3
      • Use an opening pick to pry up the antenna assembly and separate it from the MacBook Pro.
      • Watch out for the delicate ribbon cables in the middle section. Avoid sliding the pick from side to side so as not to damage the cables.
      Спросите у FixBot
    11. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 26, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 26, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 26, изображение 3 из 3
      • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink.
      • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
      Спросите у FixBot
    12. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 27, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 27, изображение 2 из 2
      • Use a T3 Torx driver to remove the four 3.9 mm screws securing the display cable cover springs.
      Спросите у FixBot
    13. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 28, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 28, изображение 2 из 2
      • Use a T8 Torx driver to remove two 4.9 mm screws from each hinge (four screws total).
      • Each hinge has a third screw, which you should leave in place for now.
      Спросите у FixBot
    14. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 29, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 29, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 29, изображение 3 из 3
      • During reassembly, first install the hinge screws without tightening them. Then adjust the screen until it is correctly centered and aligned on each side. Finally, tighten the screws.
      • If your screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
      • If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
      Спросите у FixBot
    15. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 30, изображение 1 из 2 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 30, изображение 2 из 2
      • If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following step.
      • Fully open the screen and stand your MacBook Pro up on one side.
      Спросите у FixBot
    16. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 31, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 31, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 31, изображение 3 из 3
      • Use a T8 Torx driver to remove the two remaining 4.9 mm hinge screws (one from each hinge).
      • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
      Спросите у FixBot
    17. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 32, изображение 1 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 32, изображение 2 из 3 MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 32, изображение 3 из 3
      • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
      • Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
      • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
      Спросите у FixBot
    18. MacBook Pro 15" Touch Bar 2018 Screen Replacement: шаг 33, изображение 1 из 1
      • Remove the screen.
      Спросите у FixBot
Заключение
45 человек успешно провели ремонт по этому руководству.
Jeff Suovanen
Участник с: 08/06/13
453 966 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 51 815 руководств
28 Комментарии к руководству
where can I purchase an lcd screen for this computer?
Ron Glines - Ответить Поделиться
hai jeff. Is that possible I can revive my screen not to buy a new one, instead of replacing 3 pairs of flexible cable? thanks
endyk novianto - Ответить Поделиться
To reiterate Ron’s request - you’ve shown me how to fix the screen (thank you!) without showing me where/how to purchase the replacement?
John Capehart - Ответить Поделиться
Banggodd or AliExpress but ta
Apple sry to get a genuine Apple screen as ‘compatibles’ may not pass in built Apple security- more expensive but can save a lot of heartache and later expense.
Terence Dixon - Ответить Поделиться
Pleeeaaase I really need to know where I can purchase a new screen like this one
Vico - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 14
За последние 7 дней: 123
За последние 30 дней: 523
За всё время: 110,122
