Macintosh PowerBook 165c Display Replacement
Выберете то, что вам нужно
    1. Macintosh PowerBook 165c Display Replacement, Display: шаг 1, изображение 1 из 1
      • Orientate the computer right side up and open the display case to reveal the display.
      • Use a plastic opening tool to remove the two small plastic plugs located on the display case just below the display.
      Спросите у FixBot
      Добавить комментарий
    2. Macintosh PowerBook 165c Display Replacement: шаг 2, изображение 1 из 1
      • Use a T8 torx screwdriver to remove the two, 7.7mm long screws that were revealed by removing the plastic plugs.
      • Twist counterclockwise to remove the screw.
      • Caution: Once the screws are removed, the display is only held by two screws. Handle delicately.
      Спросите у FixBot
    3. Macintosh PowerBook 165c Display Replacement: шаг 3, изображение 1 из 1
      • Grip the two bottom corners of the plastic display cover and gently pull towards yourself so that the display cover rotates about the top of the display case.
      • The display cover should release from top.
      • Remove the display case.
      Спросите у FixBot
    4. Macintosh PowerBook 165c Display Replacement: шаг 4, изображение 1 из 1
      • Locate the black connector on the right of the display. The connector can be identified by the pink, light blue, and white wires protruding from its side.
      • Remove the black connector from the circuit board by pulling it away from its adapter.
      Спросите у FixBot
    5. Macintosh PowerBook 165c Display Replacement: шаг 5, изображение 1 из 1
      • Using a T8 torx screwdriver, remove the four, 10.8mm long screws from the corners of the display.
      • Caution: The display is no longer supported and must be handled with care.
      Спросите у FixBot
    6. Macintosh PowerBook 165c Display Replacement: шаг 6, изображение 1 из 1
      • Carefully tilt the display downwards and rest it on the keyboard.
      Спросите у FixBot
    7. Macintosh PowerBook 165c Display Replacement: шаг 7, изображение 1 из 3 Macintosh PowerBook 165c Display Replacement: шаг 7, изображение 2 из 3 Macintosh PowerBook 165c Display Replacement: шаг 7, изображение 3 из 3
      • Locate the orange ribbon cable on the back of the display.
      • Open the white tab fastener by pulling it outward.
      • Remove the orange ribbon cable by gently pulling it away from the opened tab fastener.
      • The display is now free.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Jason
Участник с: 10/12/11
110 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 6-3, Regan Fall 2011 Участник Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 членов
Автор 95 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 8
За последние 30 дней: 50
За всё время: 3,008
