Maingear Vector Laptop Screen Replacement
Выберете то, что вам нужно
    • pull off the black bezel around the deges
    • it is held on by double-sided tape. be careful not to break the bezel it is a somewhat thin plastic sheet.
    Спросите у FixBot
    Добавить комментарий
  1. Инструмент, используемый на этом этапе:
    • carefully pry up the bottom of the screen. there is double-sided tape holding it to the back.
    • pry on one side at a time slowly and once you can fit a pair of tweezers befind the screen grab the tape. when yo pull the tape it will come off like 3m command hooks
    • be careful not to rip the tape
    • the tape is in two vertical strips about an inch from the edge
    Спросите у FixBot
    • the replacement screen is a lp156wfg(sp)(B2) on the maingear vector mg vctr001 1660ti from 2020
    Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. this is not a complete guide there is only enough info for you to know how to open it little steps are missing.
djluke mon
Участник с: 04/18/22
97 Репутация
1 руководство автора
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 48
За всё время: 1,137
