Введение
This guide will show you the necessary steps to replace the forward/reverse switch. It shows how to remove the battery and the outer casing, in order to locate the forward/reverse switch on the drill.
Выберете то, что вам нужно
Hold the drill upright.
Place your finger on the white battery-release button.
Slide the battery forward while pressing down on the white battery-release button.
Hold the drill upright with the back panel facing you.
Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
Apply slight pressure to the sides of the backplate and pull away from the drill.
Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
Apply slight pressure to the sides of the outer casing and pull away from the drill.
Grab onto the forward/reverse switch.
Gently pull the forward/reverse switch to separate it from the trigger assembly.
4 человек успешно провели ремонт по этому руководству.
