Managing Texas Instruments TI-92 Keyboard
Выберете то, что вам нужно
    1. Managing Texas Instruments TI-92 Keyboard, Back Cover: шаг 1, изображение 1 из 3 Managing Texas Instruments TI-92 Keyboard, Back Cover: шаг 1, изображение 2 из 3 Managing Texas Instruments TI-92 Keyboard, Back Cover: шаг 1, изображение 3 из 3
      • The first step to any repair operation is to remove the front cover.
      • Grab the back of the calculator with one hand and the cover with the other.
      • Pull the cover off from one of the sides for easy removal.
      Спросите у FixBot
      Добавить комментарий
    2. Managing Texas Instruments TI-92 Keyboard: шаг 2, изображение 1 из 2 Managing Texas Instruments TI-92 Keyboard: шаг 2, изображение 2 из 2
      • Orientate the calculator with the top facing towards you.
      • Slide the locking tab,found on the top part of the calculator, to the unlock position.
      Спросите у FixBot
    3. Managing Texas Instruments TI-92 Keyboard: шаг 3, изображение 1 из 2 Managing Texas Instruments TI-92 Keyboard: шаг 3, изображение 2 из 2
      • "Locking Tab"
      • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
      • Then with the front of the calculator facing down, pull up on the back cover.
      • The calculator should now be orientated with the front facing down, as shown in picture 2.
      Спросите у FixBot
    1. Managing Texas Instruments TI-92 Keyboard, Batteries: шаг 4, изображение 1 из 3 Managing Texas Instruments TI-92 Keyboard, Batteries: шаг 4, изображение 2 из 3 Managing Texas Instruments TI-92 Keyboard, Batteries: шаг 4, изображение 3 из 3
      • The Batteries are now exposed and the calculator is face down with the back towards you.
      • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
      • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
      • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
      • Now simply remove the battery.
      Спросите у FixBot
    1. Managing Texas Instruments TI-92 Keyboard, Texas Instruments TI-92 Back Case Disassembly: шаг 5, изображение 1 из 3 Managing Texas Instruments TI-92 Keyboard, Texas Instruments TI-92 Back Case Disassembly: шаг 5, изображение 2 из 3 Managing Texas Instruments TI-92 Keyboard, Texas Instruments TI-92 Back Case Disassembly: шаг 5, изображение 3 из 3
      • Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
      Спросите у FixBot
    2. Managing Texas Instruments TI-92 Keyboard: шаг 6, изображение 1 из 1
      • Unscrew the 19mm screw located near center of the back of the calculator.
      • Remove the panel being held by the screw.
      Спросите у FixBot
    3. Managing Texas Instruments TI-92 Keyboard: шаг 7, изображение 1 из 1
      • Using the same Phillips screwdriver, unscrew the remaining three 11.8mm screws.
      Спросите у FixBot
    4. Managing Texas Instruments TI-92 Keyboard: шаг 8, изображение 1 из 2 Managing Texas Instruments TI-92 Keyboard: шаг 8, изображение 2 из 2
      • Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
      • You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
      Спросите у FixBot
    5. Managing Texas Instruments TI-92 Keyboard: шаг 9, изображение 1 из 2 Managing Texas Instruments TI-92 Keyboard: шаг 9, изображение 2 из 2
      • Pull out the rectangular module when it is finally loose enough.
      Спросите у FixBot
    6. Managing Texas Instruments TI-92 Keyboard: шаг 10, изображение 1 из 2 Managing Texas Instruments TI-92 Keyboard: шаг 10, изображение 2 из 2
      • Now pull up on the back cover of the calculator while holding the rest of it flat on a surface.
      • Be careful not to tilt the front of the calculator at this point. The keyboard buttons are now unsupported and will fall out of place.
      Спросите у FixBot
    1. Managing Texas Instruments TI-92 Keyboard, Keyboard: шаг 11, изображение 1 из 2 Managing Texas Instruments TI-92 Keyboard, Keyboard: шаг 11, изображение 2 из 2
      • Here we will use the front panel, separate from the motherboard
      • Make sure not to tilt this part unless you want to remove all the keys from the face plate.
      • Remove the rubber contact lying on top of the keys.
      Спросите у FixBot
    2. Managing Texas Instruments TI-92 Keyboard: шаг 12, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • With the rubber contact removed the keys can now be removed to be replaced, cleaned, or manipulated in other ways.
      • To aid the removal of individual keys you can use the Ipod Opening Tool or preferably a pair of tweezers.
      Спросите у FixBot
    3. Managing Texas Instruments TI-92 Keyboard: шаг 13, изображение 1 из 3 Managing Texas Instruments TI-92 Keyboard: шаг 13, изображение 2 из 3 Managing Texas Instruments TI-92 Keyboard: шаг 13, изображение 3 из 3
      • When placing the keys back into the faceplate you have to make sure that they are going in the right direction.
      • You can tell which way is up by a semicircular extrusion on the back of a key.
      • The gray and blue keys have the extrusion on the upper left hole looking at the back of the key.
      • The black keys on the other hand have the extrusions on the lower left hole looking at the back of the key.
      Спросите у FixBot
    4. Managing Texas Instruments TI-92 Keyboard: шаг 14, изображение 1 из 3 Managing Texas Instruments TI-92 Keyboard: шаг 14, изображение 2 из 3 Managing Texas Instruments TI-92 Keyboard: шаг 14, изображение 3 из 3
      • Use the pictures shown here as guides for where the keys should go if the keys fell out or you simply chose to remove them.
      Спросите у FixBot
Заключение
Daniel Maldonado
Участник с: 04/14/10
264 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 15-51, Garner Spring 2010 Участник Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 членов
Автор 63 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 35
За всё время: 3,050
