Введение
The battery in the Marshall Emberton is responsible for giving power to the speaker and allowing it to turn on. With the help of this guide you will be able to locate the battery and changing the battery.
With an exhausted or degraded battery, battery life decreases significantly and repeated charging is required. Although the battery is located deep inside the speaker, it is very easy to replace.
Выберете то, что вам нужно
Remove the rubber casing from the speaker using your nails to peel the cover off.
Pry out both covers that are on the front and backside of the speaker to reveal the screws to get inside the speaker.
Use a TR9 screwdriver to remove the eight 1.2 cm screws.
Use a spudger or opening tool to pry out the speakers.
Use a TR9 screwdriver to remove the six 1 cm screws that secure the motherboard.
Use TR9 screwdriver to remove the final two 1.2 cm screws that secure the battery.
5 человек успешно провели ремонт по этому руководству.
5 Комментарии к руководству
Add any tools at the top you used in this repair guide and also any replacement parts if you can.
How can i buy battery
How can I buy the battery
How to buy a battery for my emberton?
From where to buy battery? What is the battery specification?
