Marshall Woburn Tweeter Replacement
Выберете то, что вам нужно
    1. Marshall Woburn Tweeter Replacement, Back Panel: шаг 1, изображение 1 из 2 Marshall Woburn Tweeter Replacement, Back Panel: шаг 1, изображение 2 из 2
      • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
      • On a flat surface, orient the device so that the front grille is facing downward.
      • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
      • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
      Спросите у FixBot
      Добавить комментарий
    2. Marshall Woburn Tweeter Replacement: шаг 2, изображение 1 из 2 Marshall Woburn Tweeter Replacement: шаг 2, изображение 2 из 2
      • Lift the back input board slightly above the back panel.
      • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
      • Fully slide the input board through the back panel and set it down gently inside the speaker.
      Спросите у FixBot
    3. Marshall Woburn Tweeter Replacement: шаг 3, изображение 1 из 1
      • Grab the panel by the large hole and lift one side until you can fit your hand under.
      • Use your hand to fully remove the back panel from the rest of the frame.
      Спросите у FixBot
    1. Marshall Woburn Tweeter Replacement, I/O Board: шаг 4, изображение 1 из 1
      • Disconnect the 5 wires circled in red from the back input board.
      • Grip and pull the connectors, not the wires.
      • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
      Спросите у FixBot
    2. Marshall Woburn Tweeter Replacement: шаг 5, изображение 1 из 2 Marshall Woburn Tweeter Replacement: шаг 5, изображение 2 из 2
      • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
      • Remove the power input from the back side of the panel.
      Спросите у FixBot
    3. Marshall Woburn Tweeter Replacement: шаг 6, изображение 1 из 1
      • Completely remove the I/O board and the attached plate.
      Спросите у FixBot
    1. Marshall Woburn Tweeter Replacement, Tweeter: шаг 7, изображение 1 из 1
      • Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the tweeters to the frame.
      • Disconnect the two wires from the back of each tweeter.
      Спросите у FixBot
    2. Marshall Woburn Tweeter Replacement: шаг 8, изображение 1 из 1
      • Lift the tweeter from the frame to remove it.
      Спросите у FixBot
Заключение
Kenneth
Участник с: 10/29/23
174 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 Участник UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G4
3 членов
Автор 12 руководств
1 Комментарий к руководству
Any ideas to which new tweeters to buy?
Lars - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 13
За последние 30 дней: 33
За всё время: 1,001
