Microsoft Surface 2 I/O Cable Replacement
Выберете то, что вам нужно
    1. Microsoft Surface 2  I/O Cable Replacement, Screen: шаг 1, изображение 1 из 3 Microsoft Surface 2  I/O Cable Replacement, Screen: шаг 1, изображение 2 из 3 Microsoft Surface 2  I/O Cable Replacement, Screen: шаг 1, изображение 3 из 3
      • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
      • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
      • Avoid touching the metal end of the gun. It will be very hot and can burn you.
      • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
      • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
      Спросите у FixBot
      Добавить комментарий
    2. Microsoft Surface 2  I/O Cable Replacement: шаг 2, изображение 1 из 3 Microsoft Surface 2  I/O Cable Replacement: шаг 2, изображение 2 из 3 Microsoft Surface 2  I/O Cable Replacement: шаг 2, изображение 3 из 3
      • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
      • Use a plastic spudger to pry the retaining clip away from the display cable.
      • The ribbon cable may be glued to the motherboard.
      • Carefully pull the ribbon cable from its socket on the motherboard.
      Спросите у FixBot
    1. Microsoft Surface 2  I/O Cable Replacement, I/O Cable: шаг 3, изображение 1 из 2 Microsoft Surface 2  I/O Cable Replacement, I/O Cable: шаг 3, изображение 2 из 2
      • Work close to Magnetic Project Map to avoid losing screws.
      • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
      • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
      • Once all screws have been removed, lift and remove the bezel from the rest of the device.
      Спросите у FixBot
    2. Microsoft Surface 2  I/O Cable Replacement: шаг 4, изображение 1 из 2 Microsoft Surface 2  I/O Cable Replacement: шаг 4, изображение 2 из 2
      • Remove the two 2.19 mm T3 screws that hold down the SD card ribbon cable.
      • Remove the two 3.27 mm T3 screws holding down the charging port.
      Спросите у FixBot
    3. Microsoft Surface 2  I/O Cable Replacement: шаг 5, изображение 1 из 3 Microsoft Surface 2  I/O Cable Replacement: шаг 5, изображение 2 из 3 Microsoft Surface 2  I/O Cable Replacement: шаг 5, изображение 3 из 3
      • Use a spudger to pry up the retaining plate at the end of the ribbon cable.
      • The retaining chip may be glued to the motherboard.
      • Use the spudger to flip up the small retaining flap on the cable's zero insertion force connector.
      • Make sure you are prying up on the retaining flap, not the connector itself.
      • Remove the ribbon cable from its port.
      • No force is needed to plug in or remove the ribbon cable.
      Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
Gregory Miller
Участник с: 02/04/16
415 Репутация
1 руководство автора
Команда
USF Tampa, Team 3-1, Wollert Spring 2016 Участник USF Tampa, Team 3-1, Wollert Spring 2016
USFT-WOLLERT-S16S3G1
4 членов
Автор 20 руководств
2 Комментарии к руководству
I want to replace the battery of Microsoft Surface 2, which steps I have to follow to replace it?
Piero Sabino - Ответить Поделиться
Cosa devo utilizzare per attaccare il cavo del display sotto al fermaglio di distanza, colla o nastro biadesivo?
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 54
За всё время: 5,300
