Введение
Use this guide to replace a worn-out or dead battery on a Microsoft Surface Laptop 3 (13.5").
Note: Some photos in this guide are from the 15” model and may contain slight visual discrepancies, but they won't affect the guide procedure.
For your safety, discharge the battery below 25% before disassembling your laptop. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
If your battery is swollen, take appropriate precautions.
You'll need replacement adhesive for the battery in order to complete this repair. Strong double-sided tape like Tesa 61395 is recommended.
Выберете то, что вам нужно
Flip the laptop over and place it on your work surface, feet facing up.
Each foot has a hidden indent that will simplify removal.
To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
Push the spudger underneath the foot and pry up to release it.
Repeat to remove the second rear foot.
Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
Repeat to remove the second front foot.
Note that the front and rear feet are different.
Note that the front feet are directional and only clip in one way.
Peel a pad away from its backing, align it over a foot cavity, and press to secure.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
Grip the top edge of upper case above the keyboard and lift straight up to release it.
Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
Remove the ribbon cable from the motherboard.
Remove the upper case.
Set the upper case onto a clean surface, keyboard-side down.
Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
Grip the end of the SSD and pull it away from its board connector to remove it.
Insert the tip of one arm of a sharp pair of tweezers into one of the holes near the top left corner of the heatsink shield.
Pull upwards to release the top left corner of the shield.
Repeat the previous step's procedure to release the top right corner of the heatsink shield.
Continue along the heatsink's top edge, inserting a tweezer arm into the shield holes and prying upwards on each one as you go.
Once the top edge is loose, use your fingers to grip the top of the shield and pull it up and away from the heatsink to release the remainder of the shield.
Completely remove the heatsink shield.
Use the pointed end of a spudger to flip up the locking flap on the fan cable's ZIF connector.
Use a pair of tweezers to pull the fan cable straight out of the connector.
Use a T3 Torx driver to remove the nine screws securing the heatsink:
One 2.5 mm screw
Three 2.0 mm screws
One 3.0 mm screw
Two 4.1 mm screws
Two 3.4 mm screws
Align the heatsink with the centering peg on the motherboard.
Tighten the four CPU tension screws in an "X" pattern.
Use the tip of your finger to lift the far right edge of the heatsink up and off of the small alignment peg near the right side of the fan on the lower case.
Once the heatsink has cleared the peg, lightly pull the right edge towards the front of the device.
Use an opening tool to pry up an edge of the metal shield covering the right side of the motherboard.
Work your way around the perimeter of the shield, prying up intermittently, until you can remove it completely.
Remove the shield.
Repeat the previous step to remove the second shield from the left side of the motherboard, closest to the CPU.
Use the pointed end of a spudger to lift and disconnect the right speaker wire from its connector on the motherboard.
Use an opening tool to flip open the gold locking arm on the Surface Connect port's motherboard connector.
Grip the Surface Connect port cable and pull it away from its connector to remove it.
Use the pointed end of a spudger to lift and disconnect the left speaker wire from its connector on the motherboard.
Use an opening tool to pry up the black shield covering the right bank of display connectors.
Repeat at different points around the shield until it becomes loose.
Remove the shield.
Repeat the previous step to remove the remaining shield from the left bank of display connectors.
Use the flat end of a spudger to pry the first display cable up and out of its socket on the motherboard to disconnect it.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of tweezers to grip the antenna cable close to its base.
Pull straight up to disconnect the cable.
Use a T3 Torx driver to remove the two 3 mm screws securing the motherboard bracket.
Use a T3 Torx driver to remove the six 2 mm screws securing the motherboard.
Four display cables
Antenna cable
Left speaker cable
Surface Connect cable
Right speaker cable
Heat an iOpener and lay it on top of the battery contact cable for about a minute, in order to soften the adhesive securing it to the case.
Slide an opening pick underneath the battery contact cable to separate it from the case.
Use a T3 Torx driver to remove the six 2.7 mm screws securing the battery to the case.
Apply adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the top edges of all three battery cell groups.
Wait 2–3 minutes for the adhesive remover to penetrate and soften the adhesive before you proceed to the next step.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Slide a plastic card underneath the far left battery cell group to slice through the adhesive holding it to the case.
Wiggle the card from side to side as you insert it under the battery cells to fully separate all adhesive holding them in place.
Leave the plastic card temporarily underneath the cell to prevent it from re-adhering while you continue.
Slide a second plastic card underneath the middle battery cell group to slice through the adhesive holding it to the case.
Slide the card out from under the middle cell group.
Slide the plastic card underneath the far right battery cell group to slice through the adhesive holding it to the case.
Leave the plastic card temporarily underneath the right cell group to prevent it from re-adhering while you continue.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$10.99
Use both plastic cards to lift the entire battery assembly up and away from the case.
Remove the battery.
If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
Carefully position the battery and set it into place. Press and hold each cell group firmly for 5–10 seconds to secure it to the lower case.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
7 участников успешно повторили данное руководство.
4 Комментариев
Thank you for showing how difficult it is to repair these devices. If it were my personal device, I’d give the task a shot. Instead, this is for work and I have to go with an option other than Surface as I have to be able to repair devices when the battery or other components fail instead of having to replace the entire device.
Wow that is so difficult. I am getting 2-3 hrs battery life. I have done a lot of DIY repairs but this look downright outrageous.
That was super tedious... but this guide made it possible thank you very much!
Here's a question I have, what happens if you don't replace the heat shields on the motherboard? It seems like no matter how careful I tried to be the only real way to get these things off is to almost destroy the pins that are holding them in place so how bad is it for thermals if they're not replaced?
