Введение
Use this guide to remove or replace the heatsink and fan in your Microsoft Surface Laptop 4 (15-inch).
If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Выберете то, что вам нужно
Unplug all cables and fully shut down your laptop.
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
The back feet recesses are closest to the back edge of the laptop.
The front feet recesses are closest to the front edge of the laptop.
Insert one arm of your tweezers into the recess of one of the feet.
Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
Remove the foot.
Repeat this process on the remaining feet.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99
The rear feet have a single center clip.
The front feet have three clips and can only be reinserted one way.
If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
Peel a pad away from its backing.
Align the pad over a foot cavity and press down to secure it.
Инструмент, используемый на этом этапе:FixMat$36.95
Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
Grip the top edge of the upper case above the keyboard and lift straight up to release it.
Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
Remove the upper case and set it keyboard-side down on a clean surface.
Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
Remove the two pieces of black tape covering the bottom left and bottom right corners of the motherboard.
Insert the pointed end of a spudger in one of the gaps on the top edge of the heatsink shield.
Gently pry up to release the clips securing the shield.
Repeat this process along the right edge.
Insert one arm of your tweezers under the bottom right edge of the heatsink shield.
Gently pry up to release the remaining clips.
Use the pointed end of a spudger to flip up the locking flap on the fan cable ZIF connector.
Grip the fan cable pull-tab with tweezers and pull the cable straight out of the connector.
Use tweezers or your fingers to peel the fan cable from the frame and separate its adhesive.
Use a T3 Torx driver to remove the ten screws securing the heatsink:
Two 2.5 mm screws
Three 2.0 mm screws
One 3.0 mm screw
Two 4.1 mm screws
Two 3.4 mm screws
Align the heatsink with the centering peg on the motherboard.
Tighten the four CPU tension screws in an “X” pattern. For example: top left, bottom right, top right, bottom left.
Insert your spudger under the left heat pipe.
Pry up to release the left section of the heatsink.
Repeat this procedure for the right heat pipe and the CPU screw mounts until the heatsink is completely separated from the motherboard.
Use your finger to lift the right edge of the heatsink up and over the alignment peg near the right side of the fan.
Lightly pull the right edge of the heatsink away from the screen to release it from its recess in the frame.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
Еще один человек закончил это руководство.
