Введение
This guide will walk through the steps to replace the shuttle spring plate on the Milwaukee M12 2407-20.
Выберете то, что вам нужно
Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
Remove metal clip located at the base of the drill, where the battery is to be inserted.
Use both hands to lift and remove the gear case assembly from the shell casing.
Set the gear case assembly aside.
3 человек успешно провели ремонт по этому руководству.
