Введение
The Parent Unit is powered by a rechargeable lithium ion type of battery. These batteries have an average lifespan of 2-3 years or 300-500 charges. This guide will show you how to replace the battery once it has reached its life expectancy.
Выберете то, что вам нужно
Using the Phillips #1 screwdriver, remove the battery cover screw.
Remove the battery cover from its hinges and set aside.
Инструмент, используемый на этом этапе:Tweezers$4.99
Lift the battery from its slot.
Using precision tweezers, grip the connector plug.
Wiggle the connector plug and pull up to remove the connecting wires.
Remove the battery from the unit and set it aside.
2 человек успешно провели ремонт по этому руководству.
