Motorola Moto E Battery Replacement
Выберете то, что вам нужно
  1. Motorola Moto E  Battery Replacement, Battery: шаг 1, изображение 1 из 2 Motorola Moto E  Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn off the device before beginning the battery replacement.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
    Спросите у FixBot
    Добавить комментарий
  2. Motorola Moto E  Battery Replacement: шаг 2, изображение 1 из 1
    • Unscrew all 14- 4mm screws located on the back part of the phone using a T4 Torx bit.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
    Спросите у FixBot
  3. Motorola Moto E  Battery Replacement: шаг 3, изображение 1 из 1
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
    Спросите у FixBot
  4. Motorola Moto E  Battery Replacement: шаг 4, изображение 1 из 1
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
    Спросите у FixBot
  5. Motorola Moto E  Battery Replacement: шаг 5, изображение 1 из 1
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
    Спросите у FixBot
  6. Motorola Moto E  Battery Replacement: шаг 6, изображение 1 из 1
    • Lift gently on the battery using the metal spudger tool.
    • The battery is stuck to the plastic case with double sided tape. You should hear the battery peeling away from the cover as you are pulling on it.
    • Obtain a new battery and place it into the plastic casing using double sided tape or whatever is provided with the new battery.
    Спросите у FixBot
Заключение
36 человек успешно провели ремонт по этому руководству.
Alex Craig
Участник с: 03/11/15
2 611 Репутация
Автор 5 руководств
Команда
Colorado Springs, Team 5-7, Panko Spring 2015 Участник Colorado Springs, Team 5-7, Panko Spring 2015
UCCS-PANKO-S15S5G7
2 членов
Автор 15 руководств
7 Комментарии к руководству
another quite superb guide from ifixit ....
I'm not surprised either as the guides on here are far and away the best available online.
keep up the good work contributors!
carol - Ответить Поделиться
is it possible to fit Moto 2 gen battery into Moto 1 gen phone ?
Clement Santhosh - Ответить Поделиться
This worked very well for me, many thanks!
Tony Franks - Ответить Поделиться
which battery type or brand should we purchase????????
hridaya123.praja - Ответить Поделиться
Excellent, clear instructions!
Gerald Griffin - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 14
За последние 30 дней: 114
За всё время: 79,405
