Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement
Выберете то, что вам нужно
  1. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Heat the edge: шаг 1, изображение 1 из 1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the edge of the back cover with the SIM card slot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
    • Apply a suction cup to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  3. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the right adhesive: шаг 3, изображение 1 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the right adhesive: шаг 3, изображение 2 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the right adhesive: шаг 3, изображение 3 из 3
    • Slide your opening pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick in at the bottom right corner to prevent the adhesive from resealing.
  4. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the bottom adhesive: шаг 4, изображение 1 из 2 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the bottom adhesive: шаг 4, изображение 2 из 2
    • Insert a second opening pick into the bottom right corner.
    • Slide this opening pick along the bottom edge to the bottom left corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
  5. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the left adhesive: шаг 5, изображение 1 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the left adhesive: шаг 5, изображение 2 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the left adhesive: шаг 5, изображение 3 из 3
    • Insert a third opening pick into the bottom right corner.
    • Slide this opening pick along the left edge to slice the adhesive.
    • Don't worry about slicing under the camera bezel. It's separate from the back cover and will be removed later.
    • Leave the pick inserted in the top left corner to prevent the left edge from resealing.
  6. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the top adhesive: шаг 6, изображение 1 из 2 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the top adhesive: шаг 6, изображение 2 из 2
    • Insert a fourth pick into the top left corner.
    • Slide the pick to the top right corner to slice the top adhesive.
  7. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice around the camera bezel: шаг 7, изображение 1 из 1
    • Slide an opening pick between the camera bezel and the back cover.
    • The back cover's adhesive is particularly strong around the camera bezel.
    • Slide the opening pick around the camera bezel to separate the back cover from the frame.
  8. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the back cover: шаг 8, изображение 1 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the back cover: шаг 8, изображение 2 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the back cover: шаг 8, изображение 3 из 3
    • Grab and remove the back cover by lifting it away from the phone.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  9. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Heat the camera bezel: шаг 9, изображение 1 из 1
    • Heat an iOpener and apply it to the camera bezel for two minutes.
  10. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the adhesive: шаг 10, изображение 1 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the adhesive: шаг 10, изображение 2 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Slice the adhesive: шаг 10, изображение 3 из 3
    • Insert an opening pick under the camera bezel.
    • Slide the pick around the perimeter of the bezel to slice the adhesive.
    • If it feels stuck, apply more heat to further loosen the adhesive.
  11. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the camera bezel: шаг 11, изображение 1 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the camera bezel: шаг 11, изображение 2 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the camera bezel: шаг 11, изображение 3 из 3
    • Grab and remove the camera bezel.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the camera bezel with custom-cut adhesives, follow this guide.
    • To adhere the camera bezel with tape, follow this guide.
  12. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Unfasten the motherboard cover: шаг 12, изображение 1 из 1
    • Use a Phillips screwdriver to remove the eleven 4.1 mm-long screws securing the motherboard cover.
    • If you can't find all the screws, check under any leftover adhesive residue.
  13. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Unclip the right edge: шаг 13, изображение 1 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Unclip the right edge: шаг 13, изображение 2 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Unclip the right edge: шаг 13, изображение 3 из 3
    • Insert a spudger between the bottom right corner of the cover and the frame.
    • Pry up to release the clips securing the cover.
    • Slide the spudger toward the top of the cover and pry to release the right edge.
  14. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the motherboard cover: шаг 14, изображение 1 из 2 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the motherboard cover: шаг 14, изображение 2 из 2
    • Grip the right edge of the cover and pull it off the motherboard.
  15. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Disconnect the battery: шаг 15, изображение 1 из 2 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Disconnect the battery: шаг 15, изображение 2 из 2
    • Use the point of a spudger to pry up the battery's press connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  16. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Heat the tape: шаг 16, изображение 1 из 1
    • Heat an iOpener and apply it to the front-facing camera for two minutes.
  17. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Peel the graphite film: шаг 17, изображение 1 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Peel the graphite film: шаг 17, изображение 2 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Peel the graphite film: шаг 17, изображение 3 из 3
    • Use the point of a spudger to lift the graphite film near the front-facing camera.
    • Use tweezers to peel the graphite film and fully expose the front-facing camera's copper tape.
  18. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Peel the copper tape: шаг 18, изображение 1 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Peel the copper tape: шаг 18, изображение 2 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Peel the copper tape: шаг 18, изображение 3 из 3
    • Use the tips of your tweezers to lift a corner of the front-facing cameras copper tape.
    • Grab and peel the copper tape from the motherboard.
    • This tape tears very easily. Work slowly and apply more heat if the tape feels stuck.
  19. Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the front-facing camera: шаг 19, изображение 1 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the front-facing camera: шаг 19, изображение 2 из 3 Motorola Moto G Stylus 5G (2022) Front-Facing Camera Replacement, Remove the front-facing camera: шаг 19, изображение 3 из 3
    • Use the point of a spudger to pry and disconnect the front-facing camera's press connector.
    • Remove the camera with your fingers or a pair of tweezers.
Заключение
Clay Eickemeyer
Участник с: 09/19/22
40 602 Репутация
Автор 280 руководств
Команда
iFixit Участник iFixit
Community
136 членов
Автор 15 135 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 129
