Motorola Moto X4 Screen Replacement
Выберете то, что вам нужно
  1. Motorola Moto X4 Screen Replacement, Heat the screen: шаг 1, изображение 1 из 2 Motorola Moto X4 Screen Replacement, Heat the screen: шаг 1, изображение 2 из 2
    • Before you begin, turn off your phone.
    • Heat an iOpener and apply it to the left edge of the phone for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take note of the the following areas:
    • Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
    • Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
    Complete novice. Getting old screen off was time consuming! I was too afraid of ruining something by overheating. Spent many hours trying to use iopener, afraid to risk bursting it in microwave. Read many comments in the iopener use guide; a guy said to get the screen temp up to 120-130F. Saw several youtube videos esp. Witrig one on replacing Moto x4 screen, they used heat gun 100C=212F so I got braver and put my phone on kitchen hot plate. Measured temperature by laying stem of candy thermometer on the surface. When hot plate got to 150-160F I finally got a pick under phone ‘s glass edge & got the screen off. Hot plate temp. not stable, guess phone was there a few minutes. May have damaged display but was replacing it anyway. Now new screen installed everything working properly! I’m not sure I was using the suction cup when I finally was able to push the pick under the edge.
    Nahariyah Mosenkis - Ответить
  2. Motorola Moto X4 Screen Replacement, Create a gap: шаг 2, изображение 1 из 3 Motorola Moto X4 Screen Replacement, Create a gap: шаг 2, изображение 2 из 3 Motorola Moto X4 Screen Replacement, Create a gap: шаг 2, изображение 3 из 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • Pull on the suction cup with strong, steady force to create a gap in the seam.
    • Insert the point of an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    On the left side it is a very thin strip of adhesive—but there are other places where there is alot more adhesive—If you look at the black part of the new adhesive-if you have the phone specific adhesive thing—you will get an idea what you might be trying to push through at any given spot on the phone. orient the new one over the old screen to line up holes etc-to understand where the adhesive is.
  3. Motorola Moto X4 Screen Replacement, Slice the screen adhesive: шаг 3, изображение 1 из 3 Motorola Moto X4 Screen Replacement, Slice the screen adhesive: шаг 3, изображение 2 из 3 Motorola Moto X4 Screen Replacement, Slice the screen adhesive: шаг 3, изображение 3 из 3
    • Slide the opening pick along the edge to slice through the adhesive.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Motorola Moto X4 Screen Replacement: шаг 4, изображение 1 из 3 Motorola Moto X4 Screen Replacement: шаг 4, изображение 2 из 3 Motorola Moto X4 Screen Replacement: шаг 4, изображение 3 из 3
    • Heat the top edge of the phone with an iOpener.
    • Carefully slice around the corner and through the top edge to separate the adhesive.
  5. Motorola Moto X4 Screen Replacement: шаг 5, изображение 1 из 3 Motorola Moto X4 Screen Replacement: шаг 5, изображение 2 из 3 Motorola Moto X4 Screen Replacement: шаг 5, изображение 3 из 3
    • Heat the screen's right edge with an iOpener.
    • Be careful not to slice too deeply near the cables to avoid damaging them.
    • Use an opening pick to slice along the right edge to separate the adhesive.
  6. Motorola Moto X4 Screen Replacement: шаг 6, изображение 1 из 2 Motorola Moto X4 Screen Replacement: шаг 6, изображение 2 из 2
    • Repeat the previous steps to heat and slice the bottom edge of the phone.
  7. Motorola Moto X4 Screen Replacement: шаг 7, изображение 1 из 2 Motorola Moto X4 Screen Replacement: шаг 7, изображение 2 из 2
    • Do not try to remove the screen yet—it is still attached to the phone by delicate flex cables.
    • Carefully lift up the left edge of the screen and cut away remaining adhesives with an opening pick.
  8. Motorola Moto X4 Screen Replacement: шаг 8, изображение 1 из 1
    • Swing open the screen and prop it up with a small box as you work on disconnecting the flex cables.
    • During reassembly, this is a good time to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  9. Motorola Moto X4 Screen Replacement, Detach the fingerprint sensor cable: шаг 9, изображение 1 из 2 Motorola Moto X4 Screen Replacement, Detach the fingerprint sensor cable: шаг 9, изображение 2 из 2
    • Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
    • Do not pull on the cable. It is still attached to the phone by a delicate ZIF socket.
  10. Motorola Moto X4 Screen Replacement, Disconnect the fingerprint sensor: шаг 10, изображение 1 из 3 Motorola Moto X4 Screen Replacement, Disconnect the fingerprint sensor: шаг 10, изображение 2 из 3 Motorola Moto X4 Screen Replacement, Disconnect the fingerprint sensor: шаг 10, изображение 3 из 3
    • Use the point of a spudger to flip up the lock bar on the fingerprint sensor's ZIF socket, near the bottom right of the phone.
    • Use tweezers to carefully slide the fingerprint sensor cable out of the socket.
  11. Motorola Moto X4 Screen Replacement, Disconnect the display cable: шаг 11, изображение 1 из 3 Motorola Moto X4 Screen Replacement, Disconnect the display cable: шаг 11, изображение 2 из 3 Motorola Moto X4 Screen Replacement, Disconnect the display cable: шаг 11, изображение 3 из 3
    • Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
    • Use tweezers to carefully slide the display cable out of the ZIF socket.
  12. Motorola Moto X4 Screen Replacement, Remove the screen: шаг 12, изображение 1 из 2 Motorola Moto X4 Screen Replacement, Remove the screen: шаг 12, изображение 2 из 2
    • Remove the screen.
    • During reassembly, follow this guide to clean the existing adhesive off and install custom-cut adhesives for your phone.
    I found that the subsequent steps will be smoother if you spend a little time at this point cleaning out the old adhesive pieces. The picture above shows pulling off some of the old glue strips, but the bullet points don’t mention it. Removing the mid-frame and other steps is easier if the old adhesive has been cleaned out.
    Gordon Bolt - Ответить
    Good point Gordon! I’ve adjusted the wording on the second bullet to point people in the right direction.
    Arthur Shi -
    I’d already used the free form adhesives to glue the screen back on before I realized the kit came with a ready-to-go adhesive sheet. It’d be nice if this were mentioned (or pictured) here.
    Paul Ferrell - Ответить
    The provided replacement screen does not have the black plastic film w/ 5 x 3 holes in it
    photo to illustrate: top is replacement screen. Bottom is old screen, w/ black film w/ holes
    Not sure how to proceed here.
    Etienne Grossmann - Ответить
  13. Motorola Moto X4 Screen Replacement, Heat the fingerprint sensor: шаг 13, изображение 1 из 1
    • Apply a heated iOpener to the fingerprint sensor for one minute to soften the adhesive gasket.
  14. Motorola Moto X4 Screen Replacement, Loosen the fingerprint sensor: шаг 14, изображение 1 из 2 Motorola Moto X4 Screen Replacement, Loosen the fingerprint sensor: шаг 14, изображение 2 из 2
    • Slide the point of a spudger under the fingerprint sensor cable and gently pry to loosen the cable from the screen.
  15. Motorola Moto X4 Screen Replacement: шаг 15, изображение 1 из 2 Motorola Moto X4 Screen Replacement: шаг 15, изображение 2 из 2
    • Use an opening tool to pry up and loosen the fingerprint sensor from the screen.
  16. Motorola Moto X4 Screen Replacement, Remove the fingerprint sensor: шаг 16, изображение 1 из 1
    • Remove the fingerprint sensor.
    • To reattach the fingerprint sensor, use a precut gasket, or apply some thin strips of Tesa adhesive to the perimeter of the sensor.
  17. Motorola Moto X4 Screen Replacement, Remove the earpiece grille: шаг 17, изображение 1 из 3 Motorola Moto X4 Screen Replacement, Remove the earpiece grille: шаг 17, изображение 2 из 3 Motorola Moto X4 Screen Replacement, Remove the earpiece grille: шаг 17, изображение 3 из 3
    • If your replacement screen did not come with an earpiece speaker grille, you will have to transfer it from your original screen.
    • The earpiece speaker grille consists of two small mesh pieces. Be careful not to lose them as you transfer them over.
    • Use the flat edge of a spudger to push the grille from the front side of the screen to loosen it from its recess.
    • Remove the grille.
    • Use some thin strips of Tesa tape to affix the grille to the replacement screen.
  18. Motorola Moto X4 Screen Replacement, Remove the microphone gasket: шаг 18, изображение 1 из 1
    • If your replacement part did not come with a lower microphone gasket, use tweezers to carefully peel it from your old screen and transfer it to your replacement part.
    • Compare your new replacement screen to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto X4 Answers community for help.
23 участников успешно повторили данное руководство.
Arthur Shi
Участник с: 01/03/18
252 842 Репутация
Автор 526 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
8 Комментариев
This guide really only covers screen removal, and should detail replacing the screen as advertised. Here are a few more steps that should be added:
1. Transferring old hardware to the new screen (seals, filters, fingerprint sensor, & the grey carbon mat.
2. Cleaning up old adhesive.
3. Applying new adhesive, whether it’s the one-piece that ifixit carries (recommended), or Tesa tape.
4. Installing the new display assembly
Andrew Parker - Ответить
Is it possible to remove and replace only the glass? Can I do that without removing the whole LCD screen and avoid disconnecting/reconnecting wires?
Drew S - Ответить
Hi Drew,
I haven’t tried, but I think it is possible to do a glass-only repair for this LCD screen, as long as you have the necessary tools and bonding adhesives. You would still have to deal with the fingerprint sensor, which is sealed onto the glass.
Arthur Shi -
I noticed the fingerprint sensor not being quite as low on the right edge after this. Also, I think it has a bit of “give” now when I press on it with a thumbnail. If the tips of my thumbs weren't so dry right now I might not have noticed, though.
Chris Young - Ответить
Hey Chris,
Did you add adhesive to the fingerprint sensor, if you didn't add some adhesive it may have some play, as most things need to be glued in place, and you could have forgotten to add some new adhesive.
Dominik Rodriguez -
I just finished following your guide and mostly satisfied. Somehow my fingerprint sensor doesn’t work but <shrugs> If I loose that convenience for a time, then I still payed less and got experience. Now, for the constructive criticism. YOU NEED a re-assembly guide. We’re not all at the level you guys are and it took a lot more work for me to put things back together as I had to flip things around and watch a few other videos to see steps I missed. You need a guide because you some of the items you’re supposed to use are not mentioned here because they’re not used until you re-assemble it. Please add it to this guide (for future people) unless you’re going to stop selling this kit, then just add it to the other kits. It would be a great help.
Ben - Ответить
Agree completely with this statement and others above. Please do re-assembly. It’s a few more photos and it makes sure you did not miss anything as this user said. At this point, in my replacement, I do not know where to start with the adhesive, etc.
Andrea -
What is the 'carbon mat'?? Is it the black backing with 15 holes that was on the inside of original screen? I'll transfer this and hope that's right. And YES . . . We definitely need ReInstall directions. I would really like to know exactly how to use the pre cut adhesive, or the Tesa tape, if needed... which I think I will. I lost the speaker screen and had to pull one from another phone. But as for other holes... I would feel much better k king I'm doing it right. It really dies no good to perfectly remove the old screen. . . If you screw up installing the new one. All in all - I'm so very Thankful this site dies exist and you guts are excellent. There's still room to grow to reach perfection ( wink**) but helping to keep the power in our hands, is priceless. I love learning and always like to know what I'm using, how it works, and how to fix it. The automotive world is pushing us further away each year. Thank you and good luck everyone.
Kristabell - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 14
За последние 30 дней: 62
За всё время: 17,104
