Введение
If you determine that your tire is flat due to a ruptured or damaged inner tube this guide will help you replace the inner tube.
Выберете то, что вам нужно
Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
Insert the flat side of the tire lever between the inside edge of the rim and the seal of the tire.
Clip the tire lever to the nearest spoke.
Insert the second tire lever next to first and slowly slide it along the outside edge of the rim until one side of the tire is off the rim.
Re-insert the first tire lever to hook the opposite seam of the tire and repeat steps 3 through 5.
To install new inner tube, follow these instructions in reverse order.
4 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Replace also means how to put it back together!
