Введение
If your screen is not working properly follow this guide to replace it.
Выберете то, что вам нужно
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
Use the plastic opening tool to remove the speaker from the casing.
Use the slim plastic opening tool to pry the camera from its position.
Unscrew the two screws that hold the volume module to the casing.
Use the plastic opening tool to slowly pry each side of the battery up.
Use the plastic opening tool to hold the camera ribbon back.
Unscrew the screw under ribbon with the screw driver.
Oriented the device so the battery is closest to the user.
Use the plastic opening tool to pry the clips up to release LCD screen.
Gently lift the northern end of the screen and slide it out horizontally.
Еще один человек закончил это руководство.
