Введение
A displaced or damaged firing spring could render your blaster futile in combat. Periodic replacement as a preventative maintenance strategy may allow you to avoid this unfortunate situation.
Modifying your blaster is not advised and may void the manufacturer’s warranty in certain states.
This blaster is equipped with a rifled barrel for maximum performance.
Выберете то, что вам нужно
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
Carefully pull the orange trigger upward and backward to remove it from the blaster.
Remove the spring from the rear of the trigger.
Еще один человек закончил это руководство.
