Nerf Vortex Vigilon Loading Spring Replacement
Выберете то, что вам нужно
  1. Nerf Vortex Vigilon Loading Spring Replacement, Removing the slide screws: шаг 1, изображение 1 из 1
    • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
    • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
    • Both sides of the slide will come off when the screws are removed.
    Спросите у FixBot
    Добавить комментарий
  2. Nerf Vortex Vigilon Loading Spring Replacement, Removing the slide pieces: шаг 2, изображение 1 из 1
    • Lift both slide pieces off of the gun.
    Спросите у FixBot
  3. Nerf Vortex Vigilon Loading Spring Replacement, Removing the outer screws: шаг 3, изображение 1 из 2 Nerf Vortex Vigilon Loading Spring Replacement, Removing the outer screws: шаг 3, изображение 2 из 2
    • Remove the twelve #00 1 cm Phillips screws.
    • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
    • Rotate the gun so that the front is facing you to remove the final screw.
    Спросите у FixBot
  4. Nerf Vortex Vigilon Loading Spring Replacement, Removing the outside cover: шаг 4, изображение 1 из 1
    • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
    • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
    • The magazine will slide down automatically as you remove the cover.
    Спросите у FixBot
  5. Nerf Vortex Vigilon Loading Spring Replacement, Removing the spring: шаг 5, изображение 1 из 2 Nerf Vortex Vigilon Loading Spring Replacement, Removing the spring: шаг 5, изображение 2 из 2
    • Lift the spring out towards you.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Cara Pew
Участник с: 09/29/14
932 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 13-6, Forte Fall 2014 Участник Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 членов
Автор 7 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 12
За последние 30 дней: 38
За всё время: 1,917
