Введение
This guide is used to replace the camera lens of the Nest Dropcam Pro. Make sure the device is unplugged before opening.
Выберете то, что вам нужно
Press in the mounting clips on each side of the case to remove the camera from the mount.
Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
Pull the motherboard away from the back case.
Unplug the red and black cable connecting the motherboard to the back case.
Lift the lens and LED assembly away from the motherboard.
Unplug the yellow and white cable from the motherboard.
Peel off the paper seal holding the Lens and LEDs together.
Disconnect the red and white wire from the bottom board.
Lift up the foam cover to reveal a second screw underneath.
Using a Philips #0 screwdriver, remove the two 3 mm screws.
2 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Where do you get replacement lens?
good morning , is there any store on the USA where i can send my drop camera ti get fix? it fell and doesn't want to broadcast any image.
