Введение
This iFixit guide shows you how to disassemble the Nikon Coolpix 995 camera, and remove/replace the LCD display.
Выберете то, что вам нужно
Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
Remove the two screws with a Phillips #00 screwdriver.
Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
Flip the camera up-side down.
Remove the two Phillips #00 screws located near the battery compartment.
Open the memory card compartment cover.
You can now see four screws under the cover. Remove all four screws.
Use your thumb to carefully lift the bottom side of the casing near the battery.
