Введение
In this guide, we will give you step-by-step instructions on how to detach the LCD screen so that it can be replaced or repaired.
Выберете то, что вам нужно
Remove the memory stick from the camera.
Remove the batteries from the camera.
Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
There is one screw hidden under the AV cover that also needs to be removed.
Remove the tape on the right side of the LCD screen.
Gently lift the LCD screen from its base.
Lift the black latch connecting the LCD ribbon to the motherboard.
Gently pull the LCD ribbon out.
8 человек успешно провели ремонт по этому руководству.
4 Комментарии к руководству
Good work! Appreciate it.
I need a new LCD screen replacement. A link to buy a new one?
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
