Nikon Coolpix L18 Lens Replacement
Выберете то, что вам нужно
    1. Nikon Coolpix L18 Lens Replacement, Back Cover: шаг 1, изображение 1 из 1
      • Remove the memory stick from the camera.
      • Remove the batteries from the camera.
      Спросите у FixBot
      Добавить комментарий
    2. Nikon Coolpix L18 Lens Replacement: шаг 2, изображение 1 из 2 Nikon Coolpix L18 Lens Replacement: шаг 2, изображение 2 из 2
      • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
      • There is one screw hidden under the AV cover that also needs to be removed.
      Спросите у FixBot
    3. Nikon Coolpix L18 Lens Replacement: шаг 3, изображение 1 из 1
      • Pry the back cover from the left side of the camera. Remove the cover gently.
      Спросите у FixBot
    1. Nikon Coolpix L18 Lens Replacement, LCD Screen: шаг 4, изображение 1 из 1
      • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
      • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
      Спросите у FixBot
    2. Nikon Coolpix L18 Lens Replacement: шаг 5, изображение 1 из 1
      • Remove the tape on the right side of the LCD screen.
      • Gently lift the LCD screen from its base.
      • Don't tug on the screen because it is still connected to the motherboard.
      Спросите у FixBot
    3. Nikon Coolpix L18 Lens Replacement: шаг 6, изображение 1 из 1
      • Lift the black latch connecting the LCD ribbon to the motherboard.
      • Gently pull the LCD ribbon out.
      Спросите у FixBot
    1. Nikon Coolpix L18 Lens Replacement, Front Cover: шаг 7, изображение 1 из 1
      • Pry back the front cover of the camera starting from the right side.
      Спросите у FixBot
    1. Nikon Coolpix L18 Lens Replacement, Lens: шаг 8, изображение 1 из 2 Nikon Coolpix L18 Lens Replacement, Lens: шаг 8, изображение 2 из 2
      • Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard.
      • Remove the LCD base plate.
      Спросите у FixBot
    2. Nikon Coolpix L18 Lens Replacement: шаг 9, изображение 1 из 1
      • Gently pull the lens ribbon out.
      Спросите у FixBot
    3. Nikon Coolpix L18 Lens Replacement: шаг 10, изображение 1 из 1
      • Desolder the connection of the motherboard to the lens ribbon using a soldering iron and desoldering wick.
      Спросите у FixBot
    4. Nikon Coolpix L18 Lens Replacement: шаг 11, изображение 1 из 1
      • Lift up the black and copper covering on the left side of the camera.
      Спросите у FixBot
    5. Nikon Coolpix L18 Lens Replacement: шаг 12, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • Pull the wiring at the top right of the camera away from the lens with tweezers.
      Спросите у FixBot
    6. Nikon Coolpix L18 Lens Replacement: шаг 13, изображение 1 из 1
      • Remove the cross-hair shaped wire cap to the left of the lens.
      Спросите у FixBot
    7. Nikon Coolpix L18 Lens Replacement: шаг 14, изображение 1 из 2 Nikon Coolpix L18 Lens Replacement: шаг 14, изображение 2 из 2
      • Remove the 3 screws holding the lens to the camera frame.
      • Two 3.8mm black Phillips #00 screws on the sides of the lens.
      • One 4.6mm silver Phillips #00 screw on the bottom of the lens.
      Спросите у FixBot
    8. Nikon Coolpix L18 Lens Replacement: шаг 15, изображение 1 из 1
      • There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the motherboard.
      Спросите у FixBot
Заключение
6 человек успешно провели ремонт по этому руководству.
Andrea Govea
Участник с: 10/11/10
373 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 9-23, Regan Fall 2010 Участник Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 членов
Автор 10 руководств
3 Комментарии к руководству
Be careful. I got painful shock from the flash capacitor even though the camera had been turned off and the batteries removed. It is the red and black wires and green tube on the left side.
Discharge it through a resistor. Trying to short it with a screwdriver made ahuge spark and left a mark on the screwdriver.
sdalimon - Ответить Поделиться
Aconteceu-me o mesmo, agora não a consigo ligar.
O meu caro Sdalimon tem alguma sugestão?
Cumprimentos.
Alberto Lopes - Ответить Поделиться
.....okay but how do I fix it???
John V - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 20
За последние 30 дней: 98
За всё время: 18,782
