Nikon D3000 On/Off Switch and Shutter Button Replacement
Выберете то, что вам нужно
  1. Nikon D3000 On/Off Switch and Shutter Button Replacement, On/Off Switch and Shutter Button: шаг 1, изображение 1 из 2 Nikon D3000 On/Off Switch and Shutter Button Replacement, On/Off Switch and Shutter Button: шаг 1, изображение 2 из 2
    • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom of the camera.
    • Remove three 3 mm x 5.5 mm Phillips head screws from the bottom of the camera near the battery cover.
    • Lift the battery cover and remove two 3 mm x 5.5 mm Phillips head screws as shown.
    • Remove the bottom cover.
    Спросите у FixBot
    Добавить комментарий
  2. Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 2, изображение 1 из 3 Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 2, изображение 2 из 3 Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 2, изображение 3 из 3
    • Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and on either side of the SD card slot cover.
    • Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
    Спросите у FixBot
  3. Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 3, изображение 1 из 2 Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 3, изображение 2 из 2
    • Lift the LCD panel off up to expose a ribbon connector. Then lift the ribbon connector tab as shown and slide the ribbon out.
    • Use this technique for all ribbon connectors in this guide.
    • Lift the LCD panel away and off the camera
    Спросите у FixBot
  4. Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 4, изображение 1 из 2 Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 4, изображение 2 из 2
    • Remove six 3 mm x 5.5 mm Phillips head screws from around the lens ring and remove the lens ring.
    • Remove two 2.5 mm x 4 mm Phillips head screws from above the lens ring to allow the front of the camera to be removed.
    • Lift and remove the grip and the front panel of the camera.
    Спросите у FixBot
  5. Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 5, изображение 1 из 3 Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 5, изображение 2 из 3 Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 5, изображение 3 из 3
    • Remove two 3 mm x 4 mm Phillips head screws from where the camera grip was just removed.
    • Remove one 2 mm x 3 mm Phillips head screw from the same location as above.
    • Remove one 3 mm x 5.5 mm Phillips head screw from the top right side of the camera shown.
    • Remove one 3 mm x 3 mm Phillips head screw from the top left side of the camera shown.
    • Gently lift the top of the camera up to separate it from the main body of the camera. At this point, it will still be connected via wires.
    Спросите у FixBot
  6. Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 6, изображение 1 из 1
    • Soldering irons are hot. Take all necessary precautions before soldering to prevent damage to the camera or yourself.
    • De-solder the wire shown on the grip side of the camera to allow sufficient access to the top of the camera.
    Спросите у FixBot
  7. Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 7, изображение 1 из 2 Nikon D3000 On/Off Switch and Shutter Button Replacement: шаг 7, изображение 2 из 2
    • Remove the ribbon connector.
    • Remove the 3 mm x 4 mm Phillips head screw and lift off the plastic bracket to expose the on/off switch underneath.
    • A quick inspection should take place before replacing the button and the metal contacts.
    • Remove the two 2 mm x 4 mm Phillips head screws and the shutter button and on/off switch will fall down away from the top of the panel.
    Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
Randall Heath
Участник с: 08/25/15
899 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 14-7, Meier Fall 2015 Участник USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 членов
Автор 6 руководств
1 Комментарий к руководству
Thanks for the guide. It was very helpful. I had problem with a shutter button. I have not replace it but disassembled and cleaned two tiny metal contacts inside, now my camera works well.
rsa91 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 42
За всё время: 5,688
