Nintendo DSi Lower Case Assembly Replacement
Выберете то, что вам нужно
  1. Nintendo DSi Lower Case Assembly Replacement, Battery Cover Removal: шаг 1, изображение 1 из 2 Nintendo DSi Lower Case Assembly Replacement, Battery Cover Removal: шаг 1, изображение 2 из 2
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
    Спросите у FixBot
    Добавить комментарий
  2. Nintendo DSi Lower Case Assembly Replacement, Taking out the Battery: шаг 2, изображение 1 из 2 Nintendo DSi Lower Case Assembly Replacement, Taking out the Battery: шаг 2, изображение 2 из 2
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
    Спросите у FixBot
  3. Nintendo DSi Lower Case Assembly Replacement, Lower Case Assembly: шаг 3, изображение 1 из 2 Nintendo DSi Lower Case Assembly Replacement, Lower Case Assembly: шаг 3, изображение 2 из 2
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
    Спросите у FixBot
  4. Nintendo DSi Lower Case Assembly Replacement: шаг 4, изображение 1 из 1
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
    Спросите у FixBot
  5. Nintendo DSi Lower Case Assembly Replacement: шаг 5, изображение 1 из 3 Nintendo DSi Lower Case Assembly Replacement: шаг 5, изображение 2 из 3 Nintendo DSi Lower Case Assembly Replacement: шаг 5, изображение 3 из 3
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
    Спросите у FixBot
  6. Nintendo DSi Lower Case Assembly Replacement: шаг 6, изображение 1 из 2 Nintendo DSi Lower Case Assembly Replacement: шаг 6, изображение 2 из 2
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
    Спросите у FixBot
Заключение
14 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
I found that lower case ribbon cable very hard to plug back in
iSzymon - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 58
За последние 30 дней: 251
За всё время: 18,599
