Nintendo Entertainment System 72-PIN Connector Replacement
Выберете то, что вам нужно
  1. Nintendo Entertainment System 72-PIN Connector Replacement, Game Cartridge Tray: шаг 1, изображение 1 из 2 Nintendo Entertainment System 72-PIN Connector Replacement, Game Cartridge Tray: шаг 1, изображение 2 из 2
    • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
    • The screws are recessed about 40 mm.
    • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
    Спросите у FixBot
    Добавить комментарий
  2. Nintendo Entertainment System 72-PIN Connector Replacement: шаг 2, изображение 1 из 2 Nintendo Entertainment System 72-PIN Connector Replacement: шаг 2, изображение 2 из 2
    • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
    • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
    Спросите у FixBot
  3. Nintendo Entertainment System 72-PIN Connector Replacement: шаг 3, изображение 1 из 3 Nintendo Entertainment System 72-PIN Connector Replacement: шаг 3, изображение 2 из 3 Nintendo Entertainment System 72-PIN Connector Replacement: шаг 3, изображение 3 из 3
    • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
    Спросите у FixBot
  4. Nintendo Entertainment System 72-PIN Connector Replacement: шаг 4, изображение 1 из 2 Nintendo Entertainment System 72-PIN Connector Replacement: шаг 4, изображение 2 из 2
    • Note: Underneath the cartridge tray is a black trapezoid-shaped tab/lip (see marker). When properly assembled this tab/lip goes below the motherboard and shielding as seen here.
    • During reassembly, make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component, causing the cartridge spring mechanism to bind.
    Спросите у FixBot
  5. Nintendo Entertainment System 72-PIN Connector Replacement, Motherboard: шаг 5, изображение 1 из 3 Nintendo Entertainment System 72-PIN Connector Replacement, Motherboard: шаг 5, изображение 2 из 3 Nintendo Entertainment System 72-PIN Connector Replacement, Motherboard: шаг 5, изображение 3 из 3
    • Remove the three 13.25mm Phillips screws that secure the motherboard to the lower case with a Phillips head #2 screwdriver.
    • Pull the motherboard assembly straight up and out of the plastic case with your hands.
    • Turn the motherboard assembly over so the metal cover is facing you.
    Спросите у FixBot
  6. Nintendo Entertainment System 72-PIN Connector Replacement: шаг 6, изображение 1 из 1
    • Disconnect the wire harnesses from the motherboard assembly:
    • Controller 1 (left)
    • Controller 2 (right)
    • Power
    • To prevent mixing the wires up during reassembly, it can be helpful to label the wires with a piece of tape.
    Спросите у FixBot
  7. Nintendo Entertainment System 72-PIN Connector Replacement: шаг 7, изображение 1 из 3 Nintendo Entertainment System 72-PIN Connector Replacement: шаг 7, изображение 2 из 3 Nintendo Entertainment System 72-PIN Connector Replacement: шаг 7, изображение 3 из 3
    • Lift off the EMI shield (metal cover) from the motherboard assembly.
    • Turn over the motherboard assembly so the 72-PIN connector is on the top of the motherboard assembly.
    Спросите у FixBot
Заключение
88 человек успешно провели ремонт по этому руководству.
nicholasweiser
Участник с: 09/22/10
2 781 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 14-40, Forte Fall 2010 Участник Cal Poly, Team 14-40, Forte Fall 2010
CPSU-FORTE-F10S14G40
4 членов
Автор 28 руководств
13 Комментарии к руководству
Because it wasn't terribly clear, the pin connector pulls off from the motherboard. Just pull straight away from the board to clear the connector. It takes some force to get it off.
Dylan Peterson - Ответить Поделиться
And, no wires need to be disconnected either.
Very easy repair.
justinlamoureux - Ответить Поделиться
"How to replace your 72 pin connector"
Leaves out the steps that show how to remove the 72 pin connector.
Priceless
punch0073735963 - Ответить Поделиться
Um are we missing the last steps on how to actually remove the 72pin connector???
Connor Gray - Ответить Поделиться
I replaced mine, and I'm still getting a solid white screen. Any ideas what else it might be?
Brandon Dixon - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 12
За последние 7 дней: 116
За последние 30 дней: 532
За всё время: 165,433
