Выберете то, что вам нужно
Эта разборка - неруководство по ремонту. Чтобы отремонтировать Game Boy, воспользуйтесь нашим сервисным руководством.
  1. Nintendo Game Boy Teardown, Nintendo Game Boy Teardown: шаг 1, изображение 1 из 2 Nintendo Game Boy Teardown, Nintendo Game Boy Teardown: шаг 1, изображение 2 из 2
    • While it wasn’t the first handheld game console to hit the market, the Game Boy popularized the category and kick-started the portable gaming industry.
    • Tech Specs: (We will see these later!)
    • 4.19 MHz 8-bit processor
    • 8 KB of RAM
    • 2.6" 160x144 STN LCD display
    • Fun fact: the LCD display was only capable of displaying four colors. Of course, those colors were just varying shades of green.
  2. Nintendo Game Boy Teardown: шаг 2, изображение 1 из 3 Nintendo Game Boy Teardown: шаг 2, изображение 2 из 3 Nintendo Game Boy Teardown: шаг 2, изображение 3 из 3
    • Denoted by model number DMG-01 (which stands for Dot Matrix Game), the Game Boy can be powered by either four AA batteries or an AC power adapter, the latter of which has unsurprisingly disappeared into the clutter abyss.
    • Despite the one model number, the Game Boy came in a handful of different models over the years, with subtle differences to the circuitry.
    • If you're wondering, that 800 number does still call Nintendo's support line, just in case you ever need some help with your retro handheld.
  3. Nintendo Game Boy Teardown: шаг 3, изображение 1 из 2 Nintendo Game Boy Teardown: шаг 3, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Mako Driver Kit - 64 Precision Bits
    $39.95
    • The case is held together by six tri-point Y1 screws. Even back in 1989, Nintendo thought traditional screws might be too easy for us tinkerers. Fortunately, our Mako Driver Kit comes with the necessary bit.
    • Do not take apart your Game Boy with standard Phillips or flathead screwdrivers. Doing so will strip your screws. If your screws are stripped, don't panic! Click here to fix it.
    • Nintendo was at least nice enough to include an indentation for our driver to nicely fit into within the battery compartment.
  4. Nintendo Game Boy Teardown: шаг 4, изображение 1 из 3 Nintendo Game Boy Teardown: шаг 4, изображение 2 из 3 Nintendo Game Boy Teardown: шаг 4, изображение 3 из 3
    • We slowly separate the two halves of the outer shell to reveal a ribbon cable booby trap! Luckily, this ribbon cable is way more robust than those you'll find in newer devices.
    • A firm grab and pull of the ribbon cable is all that stands between complete front and back separation.
  5. Nintendo Game Boy Teardown: шаг 5, изображение 1 из 2 Nintendo Game Boy Teardown: шаг 5, изображение 2 из 2
    • Once we're inside, it's all standard Phillips screws from here on out. The display's circuit board is held down with ten of them.
    • We slowly start prying from the top, as the display and circuit board are ever-so-slightly adhered to the case.
    • Do not yank the board up. This may result in... something...
  6. Nintendo Game Boy Teardown: шаг 6, изображение 1 из 3 Nintendo Game Boy Teardown: шаг 6, изображение 2 из 3 Nintendo Game Boy Teardown: шаг 6, изображение 3 из 3
    • The LCD display is attached to the circuit board with clips and a couple of screws. Unfortunately, the display's cable is soldered to the board, making display replacements a bit tricky.
    • The speaker, which is typically a modular component in many devices today, is also soldered to the board. Fortunately, it's just two wires with simple solder points.
  7. Nintendo Game Boy Teardown: шаг 7, изображение 1 из 3 Nintendo Game Boy Teardown: шаг 7, изображение 2 из 3 Nintendo Game Boy Teardown: шаг 7, изображение 3 из 3
    • The circuit boards inside the rear case are much easier to remove, with only four screws and no adhesive holding it down!
    • The mainboard, power board, and jack board are connected together and come out all at once.
    • As with the display and speaker wires, the headphone jack and other ports are all soldered to the boards.
  8. Nintendo Game Boy Teardown: шаг 8, изображение 1 из 1
    • Enhance! Here's what's on the main board of our specific model:
    • Sharp LR35902 4.19 Mhz CPU
    • LSI Logic LH5264N4T 8 KB VRAM
    • LSI Logic LH5264N4T 8 KB WRAM
    • Sharp IR3R40 amplifier
    • For some unknown reason, your board may have different chips. This may not mirror what's on your revision.
  9. Nintendo Game Boy Teardown: шаг 9, изображение 1 из 1
    • We hope you enjoyed this trip down memory lane!
    • Now, if you'll excuse us, we're going to put this thing back together and enjoy some Super Mario Land 2! Wahoo!
Craig Lloyd
Участник с: 02/10/16
42 474 Репутация
Автор 82 руководств
8 Комментарии к руководству
We truly have come a long way =) Thanks for the share.
Justin Adams - Ответить Поделиться
2020. Thanks
kajajosavic - Ответить Поделиться
Great tear down, thank you for highlighting the chips.
Jacob Shepard - Ответить Поделиться
Great tear down! I want to use an old gameboy to frame it like this:
https://images.squarespace-cdn.com/conte...
Regarding Step 7, it says here: “The LCD display is attached to the circuit board with clips and couple of screws. Unfortunately, the display's cable is soldered to the board.”
My question: what’s the best and cleanest way to remove the LCD display? It doesn’t have to function again afterwards, it just needs to look as nice and cleanly taken apart as possible :)
If anyone has a good hint, please let me know! Thanks!
Konradin Resa - Ответить Поделиться
Fanning a soldering iron back and forth on the soldered connection should do the trick!
Craig Lloyd - Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 24
За последние 7 дней: 221
За последние 30 дней: 1,006
За всё время: 65,142
