Nintendo GameCube Fan replacement for cleaning
Выберете то, что вам нужно
  1. Nintendo GameCube Fan replacement for cleaning, Top Case: шаг 1, изображение 1 из 3 Nintendo GameCube Fan replacement for cleaning, Top Case: шаг 1, изображение 2 из 3 Nintendo GameCube Fan replacement for cleaning, Top Case: шаг 1, изображение 3 из 3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
    Спросите у FixBot
    Добавить комментарий
  2. Nintendo GameCube Fan replacement for cleaning: шаг 2, изображение 1 из 3 Nintendo GameCube Fan replacement for cleaning: шаг 2, изображение 2 из 3 Nintendo GameCube Fan replacement for cleaning: шаг 2, изображение 3 из 3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
    Спросите у FixBot
  3. Nintendo GameCube Fan replacement for cleaning, Fan: шаг 3, изображение 1 из 2 Nintendo GameCube Fan replacement for cleaning, Fan: шаг 3, изображение 2 из 2
    • Using a Phillips #2 screwdriver, remove the two screws (circled in red) attaching the fan assembly to the unit.
    • Carefully disconnect the fan connector from the socket, as depicted in the second picture.
    • The controller connector panel can be gently pulled out of the main unit and laid down, as depicted. This is not strictly required, but may provide more maneuverability inside the case.
    • Make sure to not pull out the wires while removing the fan. Doing so may damage the connector wire or the PCB.
    Спросите у FixBot
  4. Nintendo GameCube Fan replacement for cleaning: шаг 4, изображение 1 из 2 Nintendo GameCube Fan replacement for cleaning: шаг 4, изображение 2 из 2
    • Once the fan is removed, use compressed air to clean the dust off of the fan blades.
    • It is highly recommended that you use a toothpick to prevent the fan blades from moving while cleaning. This will prevent accidental damage to the fans motor.
    Спросите у FixBot
Заключение
14 человек успешно провели ремонт по этому руководству.
dcarlin
Участник с: 11/05/09
399 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 6-2, Maness Fall 2009 Участник Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 членов
Автор 45 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 32
За последние 30 дней: 184
За всё время: 42,725
