Nintendo Switch Left Joy-Con Shell Replacement
Выберете то, что вам нужно
    1. Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (1/3): шаг 1, изображение 1 из 2 Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (1/3): шаг 1, изображение 2 из 2
      • Start by unscrewing the four Tri-wing Y00 screws from the back panel.
      • Keep the screws somewhere safe and organized.
      Спросите у FixBot
      Добавить комментарий
    2. Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (2/3): шаг 2, изображение 1 из 3 Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (2/3): шаг 2, изображение 2 из 3 Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (2/3): шаг 2, изображение 3 из 3
      • Insert an opening pick into the seam at the bottom edge of the controller (opposite the L and ZL buttons).
      • Slowly slide the flat edge of your opening pick up the side of the Joy-Con, opposite from the rail.
      Спросите у FixBot
    3. Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (3/3): шаг 3, изображение 1 из 2 Nintendo Switch Left Joy-Con Shell Replacement, Opening the controller (3/3): шаг 3, изображение 2 из 2
      • With the charging rail facing away from you, open the Joy-Con like a laptop.
      • Do not fully remove the back panel yet; there are still two ribbon cables connecting the charging rail to the motherboard.
      Спросите у FixBot
    4. Nintendo Switch Left Joy-Con Shell Replacement, Disconnecting the battery: шаг 4, изображение 1 из 1
      • Gently pry the battery connector straight up from its socket on the motherboard using a plastic spudger (avoid metal ones to reduce the risk of shorting components). This will keep the Joy-Con from powering on during the repair.
      • Use caution while working around the rumble module's cable which runs in the vicinity of the battery connector.
      • When handling electronics and/or batteries, it's a good idea to wear at least an anti-static bracelet.
      Спросите у FixBot
    5. Nintendo Switch Left Joy-Con Shell Replacement, Removing the battery: шаг 5, изображение 1 из 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the battery: шаг 5, изображение 2 из 2
      • Insert a spudger between the battery and the Joy-Con housing.
      • Gently pry out the battery.
      • The battery is lightly taped in place.
      • Be careful not to deform, puncture, or damage the battery.
      Спросите у FixBot
    6. Nintendo Switch Left Joy-Con Shell Replacement, Removing the battery housing: шаг 6, изображение 1 из 1
      • Remove the three 3½mm golden Phillips #00 screws from the mid-frame.
      Спросите у FixBot
    7. Nintendo Switch Left Joy-Con Shell Replacement, Accessing the controller's motherboard: шаг 7, изображение 1 из 1
      • Carefully flip the mid-frame over, away from the motherboard, as if you were turning the page of a book.
      • The flex cables are extremely fragile. It is advised to use non-sharp tweezers rather than bare hands.
      Спросите у FixBot
    8. Nintendo Switch Left Joy-Con Shell Replacement, Disconnecting the ribbon cables: шаг 8, изображение 1 из 2 Nintendo Switch Left Joy-Con Shell Replacement, Disconnecting the ribbon cables: шаг 8, изображение 2 из 2
      • Use tweezers to flip the ZIF connector lock opposite the cable.
      • The ZL button is locked in place by a small ZIF connector on the motherboard.
      • Use tweezers to gently pull the ZL button flex cable out of its ZIF connector socket. The mid-frame is now disconnected and can be removed.
      Спросите у FixBot
    9. Nintendo Switch Left Joy-Con Shell Replacement, Removing the L button: шаг 9, изображение 1 из 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the L button: шаг 9, изображение 2 из 2
      • Unlock the rail's top ZIF connector and then disconnect the cable.
      • Unlock the rail's bottom ZIF connector and disconnect the cable. You can now remove the rail from the back frame.
      • Remove the L button and its spring.
      • Be careful because the spring tends to fling away.
      Спросите у FixBot
    10. Nintendo Switch Left Joy-Con Shell Replacement, Removing the rail: шаг 10, изображение 1 из 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the rail: шаг 10, изображение 2 из 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the rail: шаг 10, изображение 3 из 3
      • Remove the screw holding the rail in place. Remove the rail from the back frame and set it off to the side.
      Спросите у FixBot
    11. Nintendo Switch Left Joy-Con Shell Replacement, Removing the latch button: шаг 11, изображение 1 из 1
      • Remove the latch button and set it off to the side.
      Спросите у FixBot
    12. Nintendo Switch Left Joy-Con Shell Replacement, Removing the triggers 1/2: шаг 12, изображение 1 из 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the triggers 1/2: шаг 12, изображение 2 из 2
      • Depress the latch underneath the trigger using tweezers. Gently pry the trigger off.
      • Make sure to note the position of the two springs under the trigger as they will need to go back in the same spot on the new mid-frame.
      Спросите у FixBot
    13. Nintendo Switch Left Joy-Con Shell Replacement, Removing the triggers 2/2: шаг 13, изображение 1 из 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the triggers 2/2: шаг 13, изображение 2 из 2
      • Remove the screw holding the circuit board for the trigger in place.
      • Remove the circuit board.
      Спросите у FixBot
    14. Nintendo Switch Left Joy-Con Shell Replacement, Removing the joystick 1/2: шаг 14, изображение 1 из 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the joystick 1/2: шаг 14, изображение 2 из 2
      • Remove the screws holding the analog stick in place.
      • The top-left screw is covered by the L button's flex cable.
      • Unlock the ZIF connector and remove the flex cable using tweezers.
      Спросите у FixBot
    15. Nintendo Switch Left Joy-Con Shell Replacement, Removing the joystick 2/2: шаг 15, изображение 1 из 2 Nintendo Switch Left Joy-Con Shell Replacement, Removing the joystick 2/2: шаг 15, изображение 2 из 2
      • Remove the analog stick.
      Спросите у FixBot
    16. Nintendo Switch Left Joy-Con Shell Replacement, Removing the top flex circuit: шаг 16, изображение 1 из 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the top flex circuit: шаг 16, изображение 2 из 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the top flex circuit: шаг 16, изображение 3 из 3
      • Remove the screws holding the flex circuit (marked by a red circle) for the minus and L buttons.
      • Remove the flex circuit.
      Спросите у FixBot
    17. Nintendo Switch Left Joy-Con Shell Replacement, Removing the minus button: шаг 17, изображение 1 из 1
      • Remove the minus button.
      • There will be a silicone membrane covering the minus button. Make sure to put it back over the minus button during reassembly.
      Спросите у FixBot
    18. Nintendo Switch Left Joy-Con Shell Replacement, Removing the motherboard 3/3: шаг 18, изображение 1 из 1
      • Remove the screws holding the motherboard in place.
      Спросите у FixBot
    19. Nintendo Switch Left Joy-Con Shell Replacement, Removing the rumble pack: шаг 19, изображение 1 из 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the rumble pack: шаг 19, изображение 2 из 3 Nintendo Switch Left Joy-Con Shell Replacement, Removing the rumble pack: шаг 19, изображение 3 из 3
      • Using a spudger, gently pry the rumble module out of its housing.
      • Remove the rumble module and the motherboard.
      Спросите у FixBot
    20. Nintendo Switch Left Joy-Con Shell Replacement, Removing the remaining buttons: шаг 20, изображение 1 из 1
      • Remove the remaining five buttons from the shell.
      Спросите у FixBot
Заключение
96 человек успешно провели ремонт по этому руководству.
Jose Castro
Участник с: 01/16/20
1 040 Репутация
1 руководство автора
Команда
University of North Texas, Team S1-G12, Raign Spring 2020 Участник University of North Texas, Team S1-G12, Raign Spring 2020
UNT-RAIGN-S20S1G12
2 членов
Автор 9 руководств
12 Комментарии к руководству
This guide was very helpful! A picture of the latch location on the trigger (step 12) would have been a big help, that step took a minute because I was putting pressure on the wrong spot.
I also noticed that most of the #00 screws were more receptive to a J00 bit. Might be worth noting in the tools section since swapping between them can strip a screw.
Fitz Montville - Ответить Поделиться
Used this guide for reference on the tools needed, someone else pointed out to use the J00 bit instead of the P00 and I’ll second that as the fit for the screws was much better, thanks for the guide much appreciated!
Lee Whittaker - Ответить Поделиться
Exactly what I needed! Dropped a set of controllers on a tile flow and the rail popped out and pulled the ribbon cables too. I picked up another iFixit toolkit with some J bits to put it back together. I don’t know why I waited this long to fix it. Charged the controllers overnight and I’m up another set now!
energy96 - Ответить Поделиться
Others above have mentioned that they needed to use a J00 bit instead of P00, but mine did not work with a J00 and was better with a P000
Jeremy Johnson - Ответить Поделиться
Small thing. In the tools list, it incorrectly says Y0 while the rest of the post correctly says Y00 for the back screws.
William Doering - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 33
За последние 7 дней: 272
За последние 30 дней: 1,181
За всё время: 112,012
