Nintendo Wii Remote Main Buttons Replacement
Выберете то, что вам нужно
  1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: шаг 1, изображение 1 из 2 Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: шаг 1, изображение 2 из 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    Спросите у FixBot
    Добавить комментарий
  2. Nintendo Wii Remote Main Buttons Replacement: шаг 2, изображение 1 из 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    Спросите у FixBot
  3. Nintendo Wii Remote Main Buttons Replacement: шаг 3, изображение 1 из 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    Спросите у FixBot
  4. Nintendo Wii Remote Main Buttons Replacement: шаг 4, изображение 1 из 2 Nintendo Wii Remote Main Buttons Replacement: шаг 4, изображение 2 из 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Спросите у FixBot
  5. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: шаг 5, изображение 1 из 2 Nintendo Wii Remote Main Buttons Replacement, Main Buttons: шаг 5, изображение 2 из 2
    • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
    Спросите у FixBot
  6. Nintendo Wii Remote Main Buttons Replacement: шаг 6, изображение 1 из 1
    • Flip over the cover, allowing the buttons to fall into your hand.
    • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
    • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
    • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
    Спросите у FixBot
Заключение
27 человек успешно провели ремонт по этому руководству.
Emily
Участник с: 04/14/13
2 015 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 3-44, Amido Spring 2013 Участник Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 членов
Автор 35 руководств
5 Комментарии к руководству
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - Ответить Поделиться
Me too, can’t find them.
Michael Velten - Ответить Поделиться
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
MartianIsotopes - Ответить Поделиться
Vinted is full of them. Although some people ask wayyy too much for them!
Sophie Nicholson - Ответить Поделиться
Yo tampoco los encuentro por ninguna parte
kinoto taller - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 18
За последние 7 дней: 72
За последние 30 дней: 330
За всё время: 49,586
