Введение
Use this guide to replace the batteries of a microlight.
Выберете то, что вам нужно
Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
Repeat this step for the bottom remaining battery.
4 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
There is another Inova flashlight design that involves removing two Phillips type screw heads that are VERY TINY. I am able to unscrew one, but not the other, so am stuck and unable to replace the batteries.
