Введение
Use this guide to change the case of a microlight.
Выберете то, что вам нужно
Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
Repeat this step for the bottom remaining battery.
Place the plastic opening tool below the LED lamp and push away from the device until you hear a click.
Continue to remove the LED lamp the with your fingers.
Place the plastic opening tool behind the logic board and bend away from the casing
Еще один человек закончил это руководство.
1 Комментарий к руководству
Great Job! found this one night while looking at my little blue light. Great tools, photos. +30
4-16-2017
