Nokia N900 Camera Replacement
Выберете то, что вам нужно
    1. Nokia N900 Camera Replacement, Camera: шаг 1, изображение 1 из 1
      • Turn the phone around to the back. Sometimes the phone's back camera slider will not work. If this situation comes about replace your back cover.
      Спросите у FixBot
      Добавить комментарий
    2. Nokia N900 Camera Replacement: шаг 2, изображение 1 из 1
      • In the case that you do need a new back cover remove it by locating the slit on the side of the phone allowing you to take off the cover, but if you need to further get to your camera you will need to remove the back cover as well.
      Спросите у FixBot
    3. Nokia N900 Camera Replacement: шаг 3, изображение 1 из 1
      • Remove the battery
      Спросите у FixBot
    4. Nokia N900 Camera Replacement: шаг 4, изображение 1 из 1
      • Now that we have taken everything off the back of the phone we will need to take a screw driver and take the six screw located on the back out of the phone. This will allow you to take apart the phone in two halves.
      • Camera
      Спросите у FixBot
    5. Nokia N900 Camera Replacement: шаг 5, изображение 1 из 1
      • You can use the blue plastic opening tool to remove the motherboard from the back of the phone.
      • The camera is located on the back of the motherboard.
      Спросите у FixBot
    6. Nokia N900 Camera Replacement: шаг 6, изображение 1 из 1
      • Your phone should now be able to separate into two pieces. One side being the back of the phone where the camera is located and the other being the side with the touch screen.
      • Back side of the phone where the camera is located
      Спросите у FixBot
    7. Nokia N900 Camera Replacement: шаг 7, изображение 1 из 1
      • Here are the two main pieces of the camera.
      Спросите у FixBot
    8. Nokia N900 Camera Replacement: шаг 8, изображение 1 из 1
      • The camera can be popped out easily using a blunt knife or credit card. A new camera unit can be put into the same place. In case a Nokia N900 camera unit cannot be found, it is possible to use a Nokia N79 camera without causing damage.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Juan Haro
Участник с: 03/13/14
284 Репутация
Автор 2 руководств
Команда
New Mexico State, Team 1-4, Easley Spring 2014 Участник New Mexico State, Team 1-4, Easley Spring 2014
NMSU-EASLEY-S14S1G4
4 членов
Автор 36 руководств
1 Комментарий к руководству
Where to find a camera part ?
Thanks
François Soltic - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 24
За всё время: 1,580
