Nokia X Rear-Facing Camera Replacement
Выберете то, что вам нужно
    1. Nokia X Rear-Facing Camera Replacement, Battery: шаг 1, изображение 1 из 1
      • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
      Спросите у FixBot
      Добавить комментарий
    2. Nokia X Rear-Facing Camera Replacement: шаг 2, изображение 1 из 1
      • To remove the battery, simply use your finger to pry the battery out of its slot.
      Спросите у FixBot
    3. Nokia X Rear-Facing Camera Replacement: шаг 3, изображение 1 из 1
      • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
      Спросите у FixBot
    1. Nokia X Rear-Facing Camera Replacement, Display Assembly: шаг 4, изображение 1 из 2 Nokia X Rear-Facing Camera Replacement, Display Assembly: шаг 4, изображение 2 из 2
      • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
      • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
      Спросите у FixBot
    2. Nokia X Rear-Facing Camera Replacement: шаг 5, изображение 1 из 2 Nokia X Rear-Facing Camera Replacement: шаг 5, изображение 2 из 2
      • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
      Спросите у FixBot
    3. Nokia X Rear-Facing Camera Replacement: шаг 6, изображение 1 из 1
      • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
      Спросите у FixBot
    1. Nokia X Rear-Facing Camera Replacement, Remove Camera: шаг 7, изображение 1 из 3 Nokia X Rear-Facing Camera Replacement, Remove Camera: шаг 7, изображение 2 из 3 Nokia X Rear-Facing Camera Replacement, Remove Camera: шаг 7, изображение 3 из 3
      • Use a spudger to disconnect the rear-facing camera ribbon cable connector from the motherboard.
      • Remove the camera module by merely picking it up out of its housing slot.
      Спросите у FixBot
Заключение
5 человек успешно провели ремонт по этому руководству.
Avery Dorsey
Участник с: 01/21/15
1 894 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 6-1, Brown Winter 2015 Участник USF Tampa, Team 6-1, Brown Winter 2015
USFT-BROWN-W15S6G1
3 членов
Автор 24 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 26
За всё время: 1,303
