Nokia XL Dual Sim Front Camera Replacement
Выберете то, что вам нужно
  1. Nokia XL Dual Sim Front Camera Replacement, Back Cover Removal: шаг 1, изображение 1 из 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
    Спросите у FixBot
    Добавить комментарий
  2. Nokia XL Dual Sim Front Camera Replacement, Battery Removal: шаг 2, изображение 1 из 2 Nokia XL Dual Sim Front Camera Replacement, Battery Removal: шаг 2, изображение 2 из 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
    Спросите у FixBot
  3. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: шаг 3, изображение 1 из 2 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: шаг 3, изображение 2 из 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
    Спросите у FixBot
  4. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: шаг 4, изображение 1 из 3 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: шаг 4, изображение 2 из 3 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: шаг 4, изображение 3 из 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
    Спросите у FixBot
  5. Nokia XL Dual Sim Front Camera Replacement, System components: шаг 5, изображение 1 из 1
    • Once the device is open, take note of all the components.
    Спросите у FixBot
  6. Nokia XL Dual Sim Front Camera Replacement, Camera Removal: шаг 6, изображение 1 из 3 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: шаг 6, изображение 2 из 3 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: шаг 6, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • With Tweezers, gently unsnap the front camera motherboard connector.
    • The front camera component can now be gently removed.
    Спросите у FixBot
Заключение
6 человек успешно провели ремонт по этому руководству.
Shadeed Bilal
Участник с: 09/25/14
231 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-4, Brown Fall 2014 Участник USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 членов
Автор 21 руководств
1 Комментарий к руководству
merci 1000 fois pour ce cite
zmohye - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 4
За последние 30 дней: 18
За всё время: 1,442
