Введение
Be cautious when removing the back panel of the device. Buttons tend to become loose and fall out of place. Some force is necessary in removing the back and front panels.
Выберете то, что вам нужно
Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
Remove the tape which holds the wiring to the battery using a plastic opening tool.
On the back side of the middle panel, pry the battery using the plastic opening tools.
5 человек успешно провели ремонт по этому руководству.
