Введение
You must remove the batteries, the front casing, the rear casing, and the motherboard before removing the lens assembly.
Выберете то, что вам нужно
The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
Six screws are 3.6 mm.
The seventh screw is 3.2 mm.
Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
These three places are located:
At the top and bottom of the battery side (opposite of side pictured) of the case.
Right in the middle of the DC-in side (side pictured) of the case.
Top of the camera, to the left of the power button.
Once those places are disconnected, the front case will pop right off.
Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
Lift the white latch using a fingernail or a spudger.
Pull the cord from its connector.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
Disconnect the ribbon cord located on the left side of the motherboard.
Use tweezers or a spudger to lift the latch on the connector.
Carefully remove the cord from the connector.
Slide the lens to the left and pull up. The lens should easily come loose and slide right out.
1 Комментарий к руководству
This is also applicable to the Olympus FE170. I dismantled and repaired mine using this guide. Excellent!
